Power Window Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Seminole, Sep 22, 2014.
  1. Sep 22, 2014 at 5:46 PM
    Seminole
    Seminole [OP] Active Member
    Jacksonville, FL
    '98 Xtra Cab SR5 V6
    98 XtraCab SR5 4WD-
    My driver side power window switch appears to be going bad. I can get the driver side window up but I have to apply a ridiculous amount of upward pressure on the switch. I have no control of the passenger side, but I can lean over and roll it up and down with the passenger side switch.
    What part do I need? Is this a straightforward replacement? I have done a couple of searches on the 1st gen forum and didn't locate any tutorials. I would greatly appreciate some insight from anyone who has been down this road.
    It's getting that time of year where you can drive with the window down in Fla! Need to get this fixed!
  2. Sep 22, 2014 at 6:43 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  3. Sep 22, 2014 at 6:52 PM
    Madjik_Man
    Colorado Front Range
    Take the 5 mins to take the master switch assembly out and clean the switch contacts.
    I have a good feeling that they are just mucked up and super dirty making it difficult to roll the driver's side window up (the contact that gets the dirtiest of all)
    I had the same symptoms: http://www.tacomaworld.com/forum/1s...djik-mans-laugh-him-build-13.html#post5935420
    Cleaning the contacts made it work like new again.
