Power window issues all 4 not working d
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ratfood, Apr 21, 2025.
  1. Apr 21, 2025 at 4:21 PM
    Ratfood
    Ratfood [OP] New Member
    2016 Grey Tacoma SR5
    None Yet
    Hi I am trying to troubleshoot my power windows. All of them stopped working all of a sudden. I am currently trying to find what all 4 windows have in common? Help please
    Things I have tried.
    1. Dash fuse box tested all the fuses
    2. Checked all 30 25 20 amp fuses under hood
    3. Power mirrors work
  2. Apr 21, 2025 at 4:33 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I'd look at the switch panel in the drivers door, could be a lose connector. I'd also make sure that the window switch isn't locked.
    Phlogiston and Ratfood[OP] like this.
  3. Apr 21, 2025 at 4:33 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    How did you check all fuses? Did you use an Ohm meter, swapping fuses with known working circuit fuse or visually looking at the fuses?
    If you only tried one of the three methods, you might try the other two.
  4. Apr 21, 2025 at 4:46 PM
    Ratfood
    None Yet
    I pulled each of them out and tested them with an ohm meter
    TA2016 likes this.
  5. Apr 21, 2025 at 6:02 PM
    TA2016
    Oregon
    Next, you may have to take the door panel off to check switches, wires that are loose or a bad regulator.
    HisDad likes this.
  6. Apr 22, 2025 at 8:09 PM
    Ratfood
    None Yet
    I just finished pulling the door panel off . Problem solved it was a loose connector. Thanks everyone
    Scotty61, CraigF, TA2016 and 3 others like this.
