Power Window/Lock Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rivrchick, Jan 6, 2012.
  1. Jan 6, 2012 at 10:28 AM
    rivrchick
    rivrchick [OP] New Member
    Taos, NM
    TRD Off Road
    Hi All. I'm new to this site, but not to Toyota. Owned and drove a '91 for 16 years and recently purchased an '08 Access Cab, about 6 weeks ago. Windows and door locks worked fine at the time of purchase, but shortly thereafter worked intermittently and now the windows don't work at all and only the passenger side door lock works using the controls on the armrest. The remote keychain will operated the locks for both sides. Any suggestions, beyond the obvious fuses, of where I should start my search for the problem (other than a dealership)? Thanks
  2. Jan 6, 2012 at 10:35 AM
    rivrchick
    Taos, NM
    TRD Off Road
    Thanks, will do
  3. Jan 6, 2012 at 3:39 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I had my drivers door lock go out around 36k. Passenger just died today.
  4. Jan 6, 2012 at 5:55 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I have looked at the wiring schematic for the windows on these trucks and everything goes through the master switch. The master can fail and cause the other switches not to work.
    There is a lock out switch on the master switch also. Check that first.:)
    X2 on the wiring. Not likely, but possible.
