Power Window Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gator16, Aug 21, 2009.
  1. Aug 21, 2009 at 4:13 PM
    gator16
    gator16 [OP] Member
    Mount Dora, FL
    Silver 06 Prerunner SR5 4 door
    I have an 06 and the driver side window is making a noise when it is raised and lowered. It is hard to explain, sounds like the track needs to be lubed or something. Has anyone else had this problem, or do you need to lube the tracks every once in a while?
  2. Aug 21, 2009 at 5:00 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Check the gaskets for rocks and things, its easy to peel them back a little. Other than that, can't really suggest much other. I haven't had any troubles with my 07. Its easy to pull the door panels off though, take a look!
