Power window- passenger side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JONNY TACO, Aug 6, 2009.
  1. Aug 6, 2009 at 4:49 PM
    JONNY TACO
    JONNY TACO [OP] Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    There are times when the front passanger can't put the window up. I have to do it from my controls. And the lock is not on- so it's not that. Anyone else have that problem:confused:
  2. Aug 6, 2009 at 4:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    may need to pop the switch cover off,unplug it and spray with some electrical contact cleaner then plug back in.....may be just a bad connection.
  3. Aug 6, 2009 at 4:54 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    No I have not had this, how many times has this occurred?
    Nevermind you are under warranty, off to the dealer with you
  4. Aug 6, 2009 at 5:48 PM
    JONNY TACO
    PA.
    I'm under warrenty and have to go to the dealer to have my new radio installed. I'll tell them about it than. It happens every now and than- maybe 4-5 times since Feb.
  5. Sep 8, 2009 at 8:25 AM
    jantolov
    jantolov Well-Known Member
    Cincinnati, OH
    09 Off-Road
    I just started noticing this problem in my 09. I have 40k miles on the truck so i am out of warranty. The passenger side window works from the driver's controls however, the passenger sometimes can not roll down the window. Did you find a fix?
