Power window problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by nmm7199, Nov 17, 2012.
  1. Nov 17, 2012 at 1:51 PM
    nmm7199
    nmm7199 [OP] Member
    Georgia
    04 SR5
    I have a 2004 Xtra Cab Tacoma. I've changed both power window switches and the motor is good when I wire it directly to a battery. ANY idea as to why my passenger side will roll down with the passenger side switch and not the driver's side...neither will roll the window up. OCCASIONALLY, they will both work. I'm thinking a bad ground somewhere? Does any one know where these are grounded so that I can check it?
    Thanks in advance!
  2. Nov 17, 2012 at 2:02 PM
    Madjik_Man
    Colorado Front Range
    Did you clean the contacts within the master switch assembly?
    My driver's side switch for my driver's side window was sporadic.
    Take it apart and spray the hell out of the contacts with electric parts cleaner and wipe clean with a swab.
    It made all the world of difference for me.
    I'm a little hesitant to say that is ultimately your problem because it doesn't work on your passenger side either. Not sure if the contacts are the issue because they are physically manipulated to connect the circuit.
    As for your question, I had my 98 door panels off and the wires that run up into my passenger side, and driver's side switch (and assembly) were all just bundled together and ran into a quick connect that plugged in under the switch. I am not sure what color wire is what but they all ran through the rubber pass through and behind the kick panel. Then they plugged in to a massive connector of many wires.
    Here's my master assembly before and after:
    The passenger side switch, for the passenger side window, are those copper and silver circular contacts in the upper right of the bottom pic. The driver's side switch for the driver's side window are those thin copper and silver blades that run vertically in the lower right of the bottom picture.
    Hope that helps
  3. Nov 17, 2012 at 2:10 PM
    nmm7199
    nmm7199 [OP] Member
    Georgia
    04 SR5
    Thanks! I'll give it a try and see. That makes sense since it is sporadic, like you say. I'll tear it apart and see what works.
  4. Nov 17, 2012 at 2:25 PM
    joes06tacoma
    Joe
    Central Coast, CA
    If you have brand new switches, and the passenger switch always will move the window down, I believe you can eliminate the switches and motor.
    My first check would be the wiring harness where it enters the driver's door. Every time you open and close your door, all the wires get flexed. I'm not aware of an issue with Tacomas, but have heard of other makes getting cracked wires in that area. The insulation may be intact, but the copper inside can be broken. Usually, the two switches are connected in such a way that a failure in the driver's side harness may affect the passenger side control.
  5. Sep 10, 2013 at 12:58 PM
    nmm7199
    nmm7199 [OP] Member
    Georgia
    04 SR5
    Do any of y'all know which wires might possibly be the culprit of this problem? I'm sure it's probably in the areas between the doors and the cabs, but if the insulation isn't broken, it's tough to figure out which one it could be.
    Thanks
  6. Sep 10, 2013 at 2:54 PM
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    I had a similar problem with my driver side window about a year ago. Sporadic operation. I checked the switches, cleaned them. It was still sporadic. I tested the motor, it TESTED good. I check all my connections, and didn't find anything wrong with the wiring. I ended up replacing the motor, and voila! It worked!
  7. Sep 16, 2013 at 7:25 PM
    nmm7199
    nmm7199 [OP] Member
    Georgia
    04 SR5
    Ok. I had a friend who runs a Japanese automotive shop dig into it today. He said that I'm not getting a ground signal coming from the main switch in the driver's door (that switch is good btw). He said that the ground comes from the ECM (if I understood him correctly). Does anyone know how to test for that or what color wire I could trace to see if I have a broken ground coming from the ECM? I'm grasping at straws, I know. Any help is greatly appreciated!
  8. Sep 16, 2013 at 7:43 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe it's a P/W relay. [​IMG]
  9. Sep 16, 2013 at 7:58 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You need a wiring schematic. If your buddy isn't able to print you one out, a Haynes or Chiltons from the parts store should have that info in it. You could also buy a AllDatadiy subscription for your truck. I have one for mine, it's very useful. They do short term 6 month subscriptions too, I want to say they are under 20 bucks.
  10. Sep 16, 2013 at 8:00 PM
    nmm7199
    nmm7199 [OP] Member
    Georgia
    04 SR5
    I have continuity on the copper terminals. Should I have it on the other 2 also?
  11. Sep 16, 2013 at 8:09 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I am looking at my diagram for a 2006, just for a general idea of how the power flow works.
    Is the situation still the same as your original post? The passenger switch works to roll down the passenger window, but not up, and the drivers switch won't operate the passenger window at all? The driver's window still works?
  12. Sep 16, 2013 at 8:11 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The relay just supplies power to the window system when the key is on. As long as he has some sign of life from the windows, the relay is okay.
  13. Sep 16, 2013 at 8:13 PM
    joes06tacoma
    Joe
    Central Coast, CA
    When you changed the switches, did you use new parts?
  14. Sep 16, 2013 at 8:24 PM
    nmm7199
    nmm7199 [OP] Member
    Georgia
    04 SR5
    Yes. I used new switches. Tested the drivers side with a new switch...replaced the passenger side. Passenger window will roll down but won't come back up. I can raise it with a wire directly from the battery to the motor. Hard to do coming down the road though ;).
  15. Sep 16, 2013 at 8:35 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Yeah, I am looking at the wiring for my truck and yours must be different, I can't visualize how a wiring failure would cause those symptoms with the way mine is wired. It would have to be a failed switch.
    So you tried a new driver's side switch, it did not make a difference, then you changed the passenger switch? Did you ever have both new switches installed at the same time. You may have a failure in both of them. That could cause these symptoms.
  16. Sep 16, 2013 at 8:38 PM
    nmm7199
    nmm7199 [OP] Member
    Georgia
    04 SR5
    Yeah. I had both new switches in and got the same result. I just didn't keep the new main switch since nothing changed.
  17. Sep 16, 2013 at 8:44 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I think your next step should be a wiring diagram, a meter, and someone to hold the switches down while you probe wires with the meter.
  18. Sep 16, 2013 at 8:46 PM
    nmm7199
    nmm7199 [OP] Member
    Georgia
    04 SR5
    Thanks for trying! I have everyone around here stumped.
  19. Sep 16, 2013 at 8:51 PM
    joes06tacoma
    Joe
    Central Coast, CA
    If anyone else is reading this and has the ability to post the wiring diagram for this system, I am very curious.
  20. Jul 25, 2016 at 12:05 PM
    MainerDave19995VZ
    MainerDave19995VZ Well-Known Member
    David
    Maine
    1999 Tacoma Extra Cab SR5 TRD 5 Speed 5VZFE
    2nd generation 16" wheels with 1.25" BORA spacers
    Hey, I'm not much help here but I'm trying to get the passenger power window switch out of the door on my 99. Is there a good video of how to get the door apart enough to pull the switch out. Not having any luck with my google searches or youtube. Thanks in advance!
