Power window replacement assembly on 2002
Discussion in '1st Gen. Tacomas (1995-2004)' started by TangoCharly, Sep 23, 2019.
  1. Sep 23, 2019 at 4:33 PM
    TangoCharly
    TangoCharly [OP] Member
    TC
    San Diego, Ca.
    2002 Tacoma 5 spd
    My drivers side window sounds like it it about to fall apart when I open or close it. I took the door panel off and can see a lot of wear on the sprocket segment that raises and lowers the window. Has anyone had this replaced or replaced it themselves?
  2. Sep 23, 2019 at 5:25 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I had a similar issue with my 99 model drivers electric window. It was easy change the regulator motor assembly. It was actually one of the easier window regulator assemblies that I've changed.
    TangoCharly[OP] likes this.
  3. Sep 23, 2019 at 6:21 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Yes, A-1 auto has what you need. You could also grab one from a junk yard but then you might come across the same problem later on down the road.
  4. Oct 19, 2019 at 3:55 PM
    TangoCharly
    TC
    San Diego, Ca.
    2002 Tacoma 5 spd
    Well, I got a replacement regulator, got the old one out no problem, however.... When I went to put the new one in I found that the connector was different! So the easy fix is just to make up a connector and go on from there. OEM has a red and blue wires, replacement is red and green. I am assuming (always dangerous) that the red wires should be mated. A1 shows what look like pigtails with different style connectors on either end so that tells me that the motor configurations can vary.
  5. Oct 20, 2019 at 5:10 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    DC motor one wire is up the other is down 50/50 you will get it correct.
    Simple to figure out with your Multi meter
  6. Oct 20, 2019 at 9:41 AM
    TangoCharly
    TC
    San Diego, Ca.
    2002 Tacoma 5 spd
    Your answer gave me my answer in a round about way. I'm going to strip the wires, jumper them and try the switch. Don't know why I didn't think about it yesterday. Probably to PO'd about the connectors not matching.
  7. Oct 20, 2019 at 5:20 PM
    det107
    det107 Well-Known Member
    Don't forget to disconnect battery before working, jammed finger(s) ain't no fun!!
