Power window switch
Discussion in '1st Gen. Tacomas (1995-2004)' started by The Raisin, Jul 24, 2011.
  1. Jul 24, 2011 at 6:23 PM
    The Raisin
    The Raisin [OP] Well-Known Member
    Mark
    Spanaway, WA
    streetqueen
    Badlands front bumper with a Smittybilt 8K winch, synthetic winch line. Demello sliders and bedbar. Custom rear bumper. Custom skid plates. Flex-a-lite tranny cooler with fan mounted in bed. Bilstein 5100's with SAW coils, AllPro UCAs, NW offroad rear springs (garbage), 4.88s and front and rear lockrights. Lots of custom sheetmetal work.
    Both of my windows are stuck in the down position. I checked for a fuse but found none the said Window. Everything else works including the door lock button. And yes I made sure the lockout button was not pressed down. I think its the switch myself. Any body know for sure if there is a fuse for the windows?
    Thanks,
    Mark
  2. Jul 24, 2011 at 7:39 PM
    BG04Taco
    BG04Taco Well-Known Member
    Edmond, OKLA
    04 2.7 SR5 4X4
    ARE Camper, JL Audio, Line-X, Yakima roof rack, odyssey 1500, red line hood struts
    15A dome?
  3. Jul 24, 2011 at 8:52 PM
    The Raisin
    Mark
    Spanaway, WA
    streetqueen
    Thanks, I will give that a try.
  4. Jul 25, 2011 at 10:15 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  5. Jul 25, 2011 at 10:05 PM
    The Raisin
    Mark
    Spanaway, WA
    streetqueen
    The switch is wore out a little bit. I pulled it apart to take a better look at it. The contacts on the up side were a little loose. I bent them in slightly and it is working fine. My local dealer wants $186.00 for a new one. I am going to scour the local junk yards for one.
