Power Windows -3 of 4 stopped working suddenly
Discussion in '1st Gen. Tacomas (1995-2004)' started by bigmanhamxd, Aug 7, 2022.
  1. Aug 7, 2022 at 10:29 AM
    bigmanhamxd
    bigmanhamxd [OP] Member
    Texas
    2004 Pre-Runner V6 2WD Double Cab Silver
    Just got my son a 04 Double Cab. Two days ago, 3 of 4 power windows stopped responding. Driver door rolls down driver window but driver door also won't roll down other three windows. Each door won't roll down it's own window either. My son said he was driving it and heard a "crackling" from front passenger door then noticed the symptom.
    I've checked 30A fuse under steering wheel, what would I check next?
    I've read of a master switch (where?) and in-door switches.
    Thx. New member.
  2. Aug 7, 2022 at 10:40 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the Forum!
    If at all possible find a copy of the Toyota Electrical Wiring Diagrams for your year Tacoma.
    Toyota calls them Double Cab.
    The Master Switch is the Drivers Door !
    All the other window switches have 2 sets of contacts that allow operation from the Master Switch and the Window switch.
    Wires tend to break in between the cab and door .
    My first step check for voltage on the right front door switch key on right door switch depressed then goo from there.
  3. Aug 7, 2022 at 3:25 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    If only the driver's window works & not the other 3, that happens when the window lock button is engaged. I would check that button first to see it's stuck or faulty. I suspect a bad master window switch.
    Don't bother looking up the price for a new OEM one, they're stupid expensive. There's aftermarket ones, some are pretty good, & not expensive. But the aftermarket ones come with a green LED that lights up the Auto indicator if that matters to you. Couldn't find one with amber LED. And that green LED is a SMD so can't swap it with the stock LED.
    https://www.amazon.com/gp/product/B004QEQJI8/
    I ended up replacing mine from another Toyota. I forget which years but certain gen Camrys & Avalons use the same master switch, just need to reuse your bezel. Oh & they come green too but I swapped the orange LED fine.
  4. Aug 7, 2022 at 3:34 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Yeah I was going to say did you accidentally press down the square button on the panel with the orange square and X (the printing may have worn off) it's extremely unusual for 3 to fail at once but sounds like the child saftey window disable button is pressed down.
    It's kinda easy to miss especially if you don't know what it does.
    bigmanhamxd[OP] and zero4 like this.
  5. Aug 7, 2022 at 3:36 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    There you go, I was having a brain fart & couldn't remember what to call it. It's too damn hot, can't think!
    Key-Rei[QUOTED] likes this.
  6. Aug 7, 2022 at 3:44 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    yea.. make sure the lock switch isnt on. this uh.. happens alot at work.
    Key-Rei likes this.
  7. Aug 7, 2022 at 4:08 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Take out the master switch and check out the contacts, my original ones were burnt black. I picked up one from eBay years ago, had to do a minor plastic shave on it to fit it. But as I said, that was years ago...;)
  8. Aug 7, 2022 at 6:35 PM
    bigmanhamxd
    Texas
    Thanks all. Edit original post for clarity of details. Will try suggestions and report back. Weekend warrior so may be a bit.
    TYVM
  9. Aug 8, 2022 at 11:01 AM
    Bivouac
    I tend to forget the window lock switch because i bump mine all the time.
    So if the right window does not work I just check the lock switch without thinking.
  10. Aug 8, 2022 at 4:49 PM
    bigmanhamxd
    Texas
    That was it! The window lock switch.
    I put too much stock in the "crackling" sound he said he heard from the passenger side thinking it was a short somewhere. When he got home I check it and that solved it.
    We can postpone that replacement for another day.
  11. Aug 9, 2022 at 6:26 AM
    Bivouac
    Glad it was an easy fix!!
