Power windows and locks not working?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 707tothe907, Nov 8, 2010.
  1. Nov 8, 2010 at 10:03 PM
    707tothe907
    707tothe907 [OP] Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    So the Other day all the sudden the power lock/unlock stopped working on the driver side... Now today while driving around all the sudden the window switches on the driver and passenger side don't work.. So only the passenger side lock/unlock works. Anyone got any clue what this could be? I haven't done anything electrical recently that could have messed with it...
  2. Nov 8, 2010 at 10:13 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    Most likely the switch on the driver's side. You can easily pop it out of the door panel, and at least make sure it's still plugged in. Check your fuses as well, it will be the one labeled "acc". on the fuse box cover, under driver side dash.
  3. Nov 8, 2010 at 10:15 PM
    707tothe907
    Jake
    Chico NorCal
    05 DCSB Off Road
    Alright thanks I'll start from
    there
