Power windows, dead battery and an untrainable idiot
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REWSTER, Aug 30, 2019.
  1. Aug 30, 2019 at 5:10 AM
    REWSTER
    REWSTER [OP] Well-Known Member
    09 TRD offroad
    Hello, here is the story. Yesterday was the 4th time I had to have my 09 dcsb jump started since I've owned it. (About a year) the reason is simple, since the head lights turn off when the key is off and the door opens I very rarely use the head lamp switch. The problem is that I sit in my truck on my work breaks and roll down the windows while I am in there. Since you need to turn the key all the way to run to roll down the windows my headlights will turn on and since I don't get out of the truck they stay on for about 20 minutes 3-5 times a day. Since I can not train myself to turn the headlights off when I park the truck I come asking this question.
    Has anyone hooked the power windows to the accessory power rather than the full run power?
    Thanks for the help.
    -Rew
  2. Aug 30, 2019 at 5:16 AM
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
    That's why I never started depending on auto lights when I bought a new truck. On the other hand I to would like to be able to roll my windows down in accessory power rather than the full run power.
    SR-71A likes this.
  3. Aug 30, 2019 at 5:19 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Welcome to Tacoma World
    I can't awnser your question, but those headlight switches can fail. I don't think it makes much of difference one way or another I like to turn off all the accessories before I shut off the vehicle. Unless I otherwise forget.
  4. Aug 30, 2019 at 5:20 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    I have not connected the windows to the accessories but need to ask what you do for work that allows 3-5 20 minute breaks?:rofl:
    Does that include a meal break too? :hungry:
    Hobbs and BassAckwards like this.
  5. Aug 30, 2019 at 5:22 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Same, I still manually switch the headlights on and off even on new vehicles. And yes, the full on key just to roll down the windows is kinda annoying
  6. Aug 30, 2019 at 5:25 AM
    REWSTER
    09 TRD offroad
    Yeah meal break also. Typical 8 hour day I get 2 breaks and a lunch. Most of the time I work 12 hour days so I throw another break in there. If I work with my manager it seems like I'm on break more than I am working because he has to get his smoke every 1.5 hours.
    Industrial maintenance.
    BassAckwards, SR-71A and PzTank like this.
  7. Aug 30, 2019 at 5:48 AM
    PzTank
    Above the Notches
    Nice... Sounds like a decent enough gig!
  8. Aug 30, 2019 at 6:27 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Sounds like a personal problem not a truck issue.
  9. Aug 30, 2019 at 7:04 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @REWSTER I believe the door motors have their own fuses. You could wire a relay that comes on with the accessories, rather than full on without the engine running.
    Maybe @Jimmyh can chime in.
    SR-71A likes this.
  10. Aug 30, 2019 at 7:24 AM
    grizquad
    grizquad Well-Known Member
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    I remember "window crank handles" so turning off everything when I turn the truck off is not really an issue.
  11. Aug 30, 2019 at 7:45 AM
    Muddinfun
    Muddinfun Well-Known Member
    Easy. One of the 1st mods I did on my truck. On the back side of the underdash fusebox are 3 relays. The middle one is for the power windows. Take it out, pop the cover off and solder the contacts together. There is 1 LED in the drivers door switch that will remain on constant, but it would probably take months to run the battery dead from that small amount of draw. If you haven't started your truck in months, it's probably not going to start anyway.
    Disclaimer: If you leave little Johnny and Susie in the truck unattended and Johnny rolls Susie's head up in the window, it's not my problem.
    SR-71A, Jimmyh and TacomaMike37 like this.
  12. Aug 30, 2019 at 8:13 AM
    REWSTER
    09 TRD offroad
    So that'll give me power at all times even key off?
  13. Aug 30, 2019 at 9:02 AM
    Muddinfun
    Yep.
    REDdawn6 likes this.
  14. Aug 30, 2019 at 9:26 AM
    REWSTER
    09 TRD offroad
    So I should be able to just run a jumper from an accessory powered spot to one of those wires to give me power in the accessory key position so little Johnny and suzie don't get guillotined unless they have the key. Right?
    MunchTIME likes this.
  15. Aug 30, 2019 at 10:43 AM
    Muddinfun
    The body ECU is what supplies power to th PW relay coil to energize the relay coil. If you're going to energize the relay coil from an accessory circuit, you're going to need to disconnect from the body ECU so that you don't back feed into the Body ECU. The ACC SKT relay right next to the PW relay is energized in the key accessory position. So, the basics, if physically possible, disconnect the PW relay coil power feed terminal and jumper to the ACC SKT relay coil power feed terminal. The limitation is going to be if you can physically make it happen. One way would be to make a whole bunch of jumpers so that the relays plug into the jumpers instead of plugging into the fusebox. That's all I've got for you. You're on your own from there.
  16. Aug 30, 2019 at 11:05 AM
    REWSTER
    09 TRD offroad
    That's helpful. Thanks.
    Muddinfun likes this.
  17. Aug 30, 2019 at 2:01 PM
    Muddinfun
    Basically like this fog light mod.
  18. Aug 30, 2019 at 2:40 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Dont forget the dog could roll the windows down if he stands on the switch too
  19. Aug 30, 2019 at 3:39 PM
    Muddinfun
    The dog can lock the doors too. I've seen that happen before. One lady I know that's a dog trainer, was successful in getting the dog to unlock the doors.
  20. Aug 30, 2019 at 3:46 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Your not the only one... I have done it once or twice as well... mine is leaving the window down when I get out and then run back to put them up only to forget about the whole auto lights thing...
