power windows operate when key in ACC position
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Weezel, Jun 26, 2010.
  1. Jun 26, 2010 at 4:07 PM
    Weezel
    Weezel [OP] Member
    North of the 49th
    4WD LB DC TRD
    bone stock!
    This drives me nuts!!! When sitting in my truck (engine off, radio on... key in ACC position) the power windows do not operate. Is there any way to fix this... tried a search but came up empty handed.
    thanks
    W
  2. Jun 26, 2010 at 4:18 PM
    swissrallyman
    swissrallyman Well-Known Member
    2017 Tacoma TRD Sport
    mine work even with the key removed, until a door is opend. Definately works in the ACC position.
  3. Jun 26, 2010 at 5:09 PM
    Weezel
    Weezel [OP] Member
    North of the 49th
    4WD LB DC TRD
    bone stock!
    I know if i turn the key one more cklick to the "ON" position they work but every vehicle I have owned that had power windows, they worked in the ACC or "accessory" position. in my head the PW's are an accessory. just bugs me I guess
    thanks
    W
  4. Jun 26, 2010 at 5:21 PM
    spp
    spp OC, Kalifornia
    OC California
    Then this must be your first Toyota then?
    I've had Fords,Nissans and Hondas and they were all just like my Toyotas.
  5. Jun 26, 2010 at 5:40 PM
    Weezel
    Weezel [OP] Member
    North of the 49th
    4WD LB DC TRD
    bone stock!
    Yes, this is my first Toyota... I was a die hard jeep guy for 20 years. I have seen the light!! I love my Tacoma! (just this window thing bugs me) LOL!
    W
  6. Jun 26, 2010 at 5:46 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    Why does it bug you? Turn the key one more click,adjust your windows,back to radio and forget about it!
  7. Jun 26, 2010 at 5:53 PM
    orvis
    orvis Well-Known Member
    Winnipeg, Canada
    06 TRD off road
    as long as you don't open the door you just have to put the key to "on" for a second and they you can put it back to acc and have your power windows, just make sure your lights are off because they will also stay on until you open the door
  8. Jun 26, 2010 at 6:47 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    This is what I do. Turn the switch to ON for just a nanosecond and then back to whatever setting I like...or even remove the keys. From the last time the key was in the ON position, you have 30 seconds (at least I think it's 30 and not 20 or 40?) to roll them up or down as you please. But if you open a door before the 30 seconds elapses, or have a door open when you do this, it cancels the timer.
  9. Jun 26, 2010 at 7:19 PM
    Weezel
    Weezel [OP] Member
    North of the 49th
    4WD LB DC TRD
    bone stock!
    Why does it bug me? Well I spend a lot of time in my truck (because of work) and if I am in there listening to the radio and I want the window down I have to turn the key on which turns off my SIRIUS radio and all the lights and buzzers and gauges and what not turn on,then I adjust my window while the radio comes on, then I switch it back ACC and the radio turns off then back on again!
    Even writing it is annoying!! Sorry to bore everyone
    W
  10. Jun 26, 2010 at 7:22 PM
    05Moose
    Jim
    Yeah, I remember that problem with satellite radio when I had it (years ago). Now everyone should understand where you're coming from on the complaint/issue.
