power windows slowing down
Discussion in '1st Gen. Tacomas (1995-2004)' started by kraze1957, Jun 1, 2009.
  1. Jun 1, 2009 at 3:17 PM
    kraze1957
    kraze1957 [OP] New Member
    Altoona,Alabama
    04 PreRunner Double cab
    chrome nerf bars, alpine cda-9885 stereo
    My 04 power windows speed is starting to slow down. Does that mean the motor is starting to die?
  2. Jun 1, 2009 at 5:52 PM
    MCRANEY
    MCRANEY WARTHOG
    CRESTVIEW FL
    03 Tacoma 4WD SR5 TRD
    3" Lift 285/75 16R Tires Aries Stainless Steel Grille Guard, KC Lights
    i have an 03 and am experiencing the same thing. hopefully someone will chime in and let us know the issue. it would be funny that both the motors go bad at the same time.
  3. Jun 1, 2009 at 7:05 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    i would asume so, but heres somthing you can try i want to but will not have another day off for the rest of this month! lube them up first??? then if not i would say it would be the motor.
  4. Jun 1, 2009 at 7:12 PM
    mneuls
    mneuls Well-Known Member
    Fort St John, British Columbia, Canada
    5100's and dakar leaf 3"lift, Satoshi grill,
    Bilstein 5100's front and back, dakar 3" leaf springs, Westin bull bar, piaa driving lights, piaa replacement bulbs, H/U, 2x10" mtx tt65 subs, 1000w clarion monoblock, Mtx surround speakers. green wire mod. Flowmaster 40, airaid intake. scanguage II.
    electric motors don't slow down, they just get hot and eventually short out. you are putting too much load on the motor, that'll slow it down. Dust accumulates in the slides of the winow mechanism. you might have to open up the doors, use some brakkleen or something and clean out the rails that the window opener operates on, then lube with graphite or lithium grease when dry. the whole assembly can be removed as well, to make cleaning and lubing easier.
  5. Jun 1, 2009 at 7:16 PM
    jeff6001
    jeff6001 Well-Known Member
    San Antonio, TX
    99 trd prerunner
    Good to know. My 99 rattales around like their is no coushion in between my door and me.
  6. Jun 1, 2009 at 7:46 PM
    mneuls
    how do you mean? the window rattles back and forth, or something inside the door?
  7. Jun 2, 2009 at 12:03 AM
    jeff6001
    San Antonio, TX
    99 trd prerunner
    Nah. When the window is all the way down it sounds like there is no padding or its lose in the door. IDK if i have to tighten anything or add something.
  8. Jun 2, 2009 at 9:18 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    sounds like somethings loose in the door, either the regulator or the track
  9. Jun 2, 2009 at 9:36 PM
    mneuls
    ya, you might need to replace the teflon bushings on the slides. I'd just pop the door apart and wiggle it to see whats up.
  10. Jun 3, 2009 at 3:33 PM
    SLS09
    SLS09 New Member
    The Senator
    Florida
    SR5 Access Cab - 2014
    none yet
    had my 2001 windows lubed and they are operating much faster
