Power windows stopped working.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jessemanny75, Dec 4, 2024.
  1. Dec 4, 2024 at 7:40 PM
    jessemanny75
    jessemanny75 [OP] New Member
    Chuy
    2007 Toyota Tacoma SR5 Access Cab
    GTA Car Kit
    Hope someone can help me diagnose the problem with my Power Windows. I replaced the two doors switch from A1Auto, it took a while during the summer and it started to work then it stopped again. Windows are up on both sides currently. I checked the fuses and and even replaced them it still doesn't work. I checked for power to the drivers door switch and it's getting the voltage. The passenger only locks the doors and the door lock on the driver's side does work but it lights up when I press it. Any suggestions? Got 265K miles on my Access cab and it's my daily driver.
  2. Dec 4, 2024 at 7:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It likely a ground issue.
    The switch just opens and closes a ground.
    Let me get back to you in a bit.
    Somewhere on here, there is a post I did on it and how to diag the circuit.
    let me see if I can find it.
    jessemanny75[OP] likes this.
  3. Dec 4, 2024 at 7:48 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you verified Ground on Pin 1 (White/Black)?
    Are you sure you have the correct switches? 05-11 and 12-15 have different pinouts.
  4. Dec 5, 2024 at 7:34 PM
    Birdogsetter
    Birdogsetter Member
    09 Tacoma
    With the dome light on watch it and push the windows switch ,if the dome light dim's it's probably the windows motor.. Sometimes you can bang the door where the motors mounted and it might start working for a bit....
