Power wire through frame
Discussion in 'Audio & Video' started by mrmumbels, Dec 11, 2010.
  1. Dec 11, 2010 at 8:01 AM
    mrmumbels
    mrmumbels [OP] Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
    Has anyone run their power wire through the frame and if so is there a specific route that's best?
  2. Dec 11, 2010 at 8:07 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    power wire for what?
  3. Dec 11, 2010 at 8:08 AM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    I've run power wire through frames but mainly for compressors. I like to keep to the inside of the frame rail, and use something to hold it in place if possible like this:
  4. Dec 11, 2010 at 8:12 AM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    x2
  5. Dec 11, 2010 at 9:22 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    Stereo power
  6. Dec 11, 2010 at 10:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Is there a reason it needs to be inside the frame? It can be done, just a pain in the ass. You might be able to use the string and shop-vac trick to get your route. Also depends on how thick the wire is. The issue is if chaff the wire during install or over the course of some time while driving, you'll never know it. Just get some wire loom and run the wire next to the frame and zip tie it to keep it secure.
  7. Dec 12, 2010 at 1:44 AM
    Ihnaer
    Ihnaer Well-Known Member
    Sacramento, Ca
    18 TRD Off-Road
    TRD pro grill TRD rhino liner’d skid plate C4Fab Front Bumper w/ winch and Baja Lights DCDC 2nd battery ARB compressor Switchpros GMRS hidden radio Expedition Essentials dash mount Old Man Emu 2" lift DCDC Trailer charging port LED taillight upgrade Weboost cell amp
    Why would you even bother? It has to come back in the cab anyways and thats just another hole in the floor. Use the wire harness boot in the farewall and run it down the door sil channel. they are HUGE. Just remember RCA and speaker on one side and power on the other. its extra wire, but a few bucks of wire is a small price to pay for less interference.
  8. Dec 13, 2010 at 7:13 PM
    Miata Tech
    Miata Tech Well-Known Member
    Jim
    Lawrence, KS
    2002 4X4 SR-5 TRD
    ChaseCam Video System, Optima YellowTop, ScanGauge II, Heated Drivers Seat, Sirius Satellite Radio, K&N Drop In, E-Locker Guard, Extang Black Max Tonneau , Streamlight Stinger, All Synthetic Fluids, USA-Spec iPhone Interface, Gentex Auto Dimming Compass/Temp Mirror
    Another option would be to use a Ancor Marine Grade Electrical Wire Seal.
    Looks a lot tricker than just pushing the wires through the wiring harness gromet.
    IMG_0046.JPG by Starwind 19, on Flickr
  9. Dec 13, 2010 at 7:18 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    Nice miata. I already found a great spot through the frame and came up into the compartment under the rear seats and used a rubber grommet I found at autozone.
  10. Dec 13, 2010 at 7:38 PM
    C5RACNG
    C5RACNG Member
    Dave
    Boca Raton, FL
    08 XRunner SWB
    I agree, just ran 4g thru the large boot and right down the channel,
    came thru the firewall just where I wanted it
  11. Dec 14, 2010 at 8:43 AM
    81shark
    81shark Well-Known Member
    you guys are working too hard. there is a hole in the firewall down by the brake booster for this. you remove the kick panel on the driver side, and the plastic covers down the side and bam, you are done.
    keep it simple
  12. Dec 14, 2010 at 9:19 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    I was trying to keep it simple not realizing the door jam tracks were that huge. I still would have had to go from the rear door jam to the underseat compartment so maybe running it through the frame was for the best. It's 1/0 ga btw
  13. Dec 14, 2010 at 9:38 AM
    Pugga
    Massachusetts
    Just make sure it's protected. If you chaff it within the frame, you'll never know it until you short something out.
  14. Dec 14, 2010 at 3:50 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    It should be ok. I tied it in good so there's no movement. Plus, have you ever seen the surround on a 1/0 ga cable? Crazy stuff.
  15. Dec 14, 2010 at 4:46 PM
    Pugga
    Massachusetts
    I'm more referring to when you pull the wire through. Yes, I know what the surround on a wire like that looks like and it's that thick for a reason. It's very easy to skin the protection off a wire like that when you're pulling it through a frame with some sharp rust spots or metal burrs and you have no way to inspect it when you're done. Just playing devil's advocate and trying to tell you some of the pit-falls so you can avoid damage to your set-up.
  16. Dec 14, 2010 at 5:10 PM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    I use several thousand of these at work every year. They are great little waterproof fittings. I am using them on my truck with the new wiring set-up and battery relocation.
    If anybody wants to go this route I have great contract price on them (retail is like 17 bucks). I think I can send them out for like 12 bucks shipped.
  17. Dec 15, 2010 at 1:17 PM
    rscecil007
    rscecil007 Well-Known Member
    Seattle
    06 4x4 TRD Sport Access Cab
    Goodyear Duratracs 265/70R17's, Bed mat & extra d-rings, Weathertech floor liners, Husky Liner for rear seat area, Biceman Illuminated 4x4 Switch, Pioneer 800 PRS, Hybrid Audio L6 and L1V2, JL 13TW5 in a Mr. Marv box, JL HD900/5
    There was a guy on the x-runner forum that ran his power wire though the frame. Conveniently enough, you can dive right into the frame right under the battery in the engine bay, and there are tons of grommets already in the floor throughout the cab you can use . This one guy used one to come up right under the rear seat, IIRC.
    1/0g is big, but you can run it down the door sill channels. I had some like that at one point.
  18. Dec 15, 2010 at 1:27 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Maybe you shouldn't have used 1/0 gauge, sheesh! 4 gauge can carry up to 60A 20 feet, dude.
    Just out of curiosity, what are you powering? (Besides a welding machine :p)
  19. Dec 15, 2010 at 7:14 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I ran 2 gauge through the stock grommet there with no issues. Went right down the track with plenty of room to spare.
    If you run the wire outside the truck I'd suggest using welding cable. I use welding cable anyways regardless of where I run it but the jacket on it does better when exposed to the elements.
