Powerbuilt All in one bottle jack and jack stand
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe23, Feb 6, 2017.
  1. Feb 6, 2017 at 4:58 PM
    Joe23
    Joe23 [OP] Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I ordered. figure I'll be a test.
    I'll report back how it is after trying it out, based on stock truck.
  2. Feb 6, 2017 at 5:49 PM
    FiaCobra
    FiaCobra Well-Known Member
    I picked up one for my "non lifted" Taco. Figured for the street, this would be 100% better than the factory jack they give us. I store it in the tool box that's in the bed.
    Joe23[OP] likes this.
  3. Feb 7, 2017 at 4:59 AM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    @Joe23 Just my opinion, but this sorta reminds me of a spork. Handy in a pinch but inferior to the individual tools.
    Think through the most common instances where you're putting the truck in the air. Don't need it for oil changes, there's plenty of room underneath even stock. It'd generally be when making mods (rare), fixing a flat (rare), working on brakes (infrequent), rotating tires (every 5K), or maybe swapping summer/winter tires & wheels (2x/yr).
    What's the easiest solution for each of those instances? For tire rotations, a floor jack and four jack stands make the job very easy. Lift the front center lift point and put the frame on two stands. Lift the rear differential and put the rear axle on two stands. Cross-rotate tires with no muss or fuss. On my Wrangler I did a five-wheel rotation this way.
    Speedbird and Joe23[OP] like this.
  4. Feb 7, 2017 at 5:15 AM
    PottMatter
    PottMatter Well-Known Member
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
  5. Feb 8, 2017 at 6:17 PM
    Joe23
    So it came today.
    Found it worked great.
    Love the flat base. The jack stand portion is adjustable with 3 spots, with the middle one it sits right on the frame so you can get a pretty good amount of lift with it.
    Figure each hole is an inch apart so should be fine even after lift with full length option and a 2x10 under it (which I'll still likely do just to not damage the driveway)
  6. Dec 31, 2023 at 6:18 PM
    fullsend604
    fullsend604 Well-Known Member
    2018 Tacoma TRD Sport 4x4 DCLB
    Yukon 5.29 gears, Eaton ELocker, Stoptech 6 Piston front BBK + Stoptech 4 Piston rear BBK conversion (Tundra master cylinder upgrade), 315/70R17 Falken Wildpeak AT3W, Advan RG-D2 17x8.5 wheels (Indigo Blue), Fox 2.5 PE mid travel w/DSC adjust, Icon RXT leaf pack, DRT shackle hangers w/crossbar, BTF high caster LCA, SPC UCA, OVTune 5.29 (87 regular tune), C4 Hybrid front bumper (30" Rigid light bar + 3" pods), C4 Rock Runner HC rear bumper (Baja Designs S1 wide cornering reverse lights), C4 oversized tire fender kit, Cali Raised trail rock sliders, Cali Raised Overland bed rack, Cali Raised bed stiffeners, RCI engine/trans/tcase skids, CBI fuel tank skid, Prinsu cab rack, Borla Type-S exhaust, Morimoto XB LED head + tail lights.
    Old ass thread revival, how is this for off-road use? Looking at this jack on Amazon plus the rubber saddle which sits on top between the frame and jack to give it a little bit extra lift. My concern is that this jack is rated 11-21" the rubber saddle maybe gives it an extra inch. My truck is lifted and my frame is about 18" off the ground which means I'll only be able to lift it by 3" before topping out. I don't even think that will get my tire off the floor on the trail will it? I'm on 35" tires.
    OG_Tacoma likes this.
