Powerchip
Discussion in 'X-Runners' started by XRTRD, Jul 2, 2008.
  1. Jul 2, 2008 at 2:21 PM
    XRTRD
    XRTRD [OP] Member
    CA
    2007 X-Runner SWB
    NoNe
    looking to buy a peformance chip so far all i found was the unichip and the mapecu2 from urd and ttc sells them aswell? any one have one? If so wut u got out of them
  2. Jul 2, 2008 at 2:24 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
  3. Jul 2, 2008 at 2:29 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    +1
    dont even bother with the other chips
  4. Jul 2, 2008 at 2:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, other "chips" are just resistors that "trick" your ECU into thinking its gettting cooler air than it really is. The URD MAF calibrator is the only real tunning system for our trucks. :)
  5. Jul 2, 2008 at 3:34 PM
    hail-bop Command
    hail-bop Command Well-Known Member
    I Don't Crawl I Haul A$$!
    Most of us just need to figure out how the hell to tune them.
  6. Jul 2, 2008 at 3:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Easy! A dynomometer, and a Laptop. :D
  7. Jul 2, 2008 at 3:43 PM
    hail-bop Command
    Easier said then done & hwat about a scanguage & db guage?
  8. Jul 2, 2008 at 3:43 PM
    tacoskim
    Los Angeles, CA
    Stock
    and a couple more hundred dollars later :D:D:D
  9. Jul 2, 2008 at 3:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Unless you have "friends" :cool:
  10. Jul 2, 2008 at 3:45 PM
    tacoskim
    Los Angeles, CA
    Stock
    which i need to find!
  11. Jul 2, 2008 at 3:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With the right software, you can see all the needed info on the laptop. You really dont need a db guage. Thats only for exhausts. :)
  12. Jul 2, 2008 at 4:11 PM
    hail-bop Command
    The BD guage is to see your AF Ratio reading for the necessary adjustments to the MAF calibrator. How you going to know if your running to lean or to rich with no DB guage?
  13. Jul 2, 2008 at 4:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought you were talking about "db" as in Decible, I.E. sound pressure....LOL.., yes, the you do need to know the AFR, and most Dyno shops monitor that when you do a run. :)
  14. Jul 2, 2008 at 5:01 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Is there a noticeable improvement when you install one of there? Ive been looking at them and dont see much info on the site.
  15. Jul 2, 2008 at 6:48 PM
    XRTRD
    XRTRD [OP] Member
    CA
    2007 X-Runner SWB
    NoNe
    well i got an volant intake and going to get dtlt headers, i got the afr gauge thanks to one of my friend and now i need the chip, by the looks of it u all have good review on the URD, which one r u exacly talking about cause theres like 5 of them, just need it to run the setup i have now and then for more upgrades like for the trd blower.
  16. Aug 17, 2008 at 1:52 AM
    PwRTRIp_Xr
    PwRTRIp_Xr Active Member
    Im running urd maf calibrator.....
  17. Aug 17, 2008 at 5:22 AM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    So does anybody know the performance gains of the URD MAF?
    1/4 mile
    0-60
    HP/torque curves
    MPG
  18. Jan 4, 2009 at 5:39 PM
    carolinyens
    carolinyens Creedmoor Connections
    Durham, NC
    08 X-Runner
    TRD CAI, TRD SS, Toyota All Weather Mats, Eagle Eye Halos, NST Crankshaft Pulley, ScanGauge II, TRD Shiftball, TRD SeatCovers, WeatherTech Vent Visors, 20% tint, DTLT's and NST pulley combo.
    I know its an old thread but from what Ive gathered so far it adds at least 10+hp depending on what you have and the custom tune for it. Also depends on the elements(weather). I dont think it helps MPG. Theres no distinct answer that I can find. Theres a dyno sheet on the URD site on a stock 1GR-FE but you cant tell what it says. (It wouldnt matter anyway cause I dont know how to read em)
