Powered sub help
Discussion in 'Audio & Video' started by jtc411, Jun 9, 2020.
  1. Jun 9, 2020 at 10:15 AM
    jtc411
    jtc411 [OP] Active Member
    Justin
    2020 Tacoma TRD Sport 4x4
    Hey all new to installing a powered sub on a stock head unit. I need to run high level speaker outputs for the Rockford Fosgate 8” powered sub. I don’t want to go back to the head unit and run wires. Where is the best place to tap after the head unit to run high levels? Anyone have directions or pics? Thanks
  2. Jun 9, 2020 at 10:25 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    While I dont know if the 2020 headunit has the same issue, on the 2016-2019 headunits, the rear speakers were very very quiet, so tapping into the rear speakers for the sub made a very quiet sub.
    So, with that said, in the drivers side kick panel is the plug for the door harness. Go here to tap into the front speakers and then run the wires along the side to where your sub is.
  3. Jun 9, 2020 at 4:07 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Why exactly are you against going behind the head unit? That’s the best and easiest place for sure
  4. Jun 9, 2020 at 4:28 PM
    jtc411
    Justin
    Against it would probably be harsh, I just don’t know that it’s necessary considering a lot of people seem to tap the speakers.
