Powered Subwoofers, good or bad?
Discussion in 'Audio & Video' started by Zombie, May 10, 2011.
  1. May 10, 2011 at 8:57 PM
    Zombie
    Zombie [OP] I miss my Taco
    Tucson, AZ
    06 4x4 double cab (Sold)
    My 06 Double cab Taco has aftermarket highs and mids, but no bass. I want to keep as much space, and save money so I was considering a powered sub. From the research I've done, I really like the Infinity Basslink 10'' Sub. Anyone else running this sub or other powered subs?
  2. May 10, 2011 at 9:19 PM
    RAMZAK
    RAMZAK Well-Known Member
    Mark
    Houston
    2008 Tacoma TRD 4-DR PreRunner
    As former installer(paid for Engineering degree installing stereos), I can tell you that:
    Powered subwoofers are a perfectly matched Subwoofer, Amp, and Box.
    They sound great and are usually VERY reliable.
    Due to this reliability, the setup dosent push the Db, Bass, and Sound limits as much as you could using your own custom setup.
    Bottom line, you will never achieve the crazy "hear-it-in-the-car-next-to-you" bass like you would with a seperate custom setup. But you will however get a great, clear sounding, reliable package at a fair price.
    It really depends on what your ultimate goal is.
    Here are a couple things to think of....
    Currently your door speakers are playing the lower sounds (bass). When you add the sub, you want the sub to be the ONLY speaker playing low frequencies. This is because the smaller door speakers are woofers, not sub-woofers and cannot reproduce lower frequencies very well.
    If you DONT add an amp with a crossover built into it. You want to either have a head unit(aftermarket) that can block the lower frequencies from the door speakers OR install "bass blockers" on the positive wires for every door speaker(you will need 4 total, they are sold in pairs of 2's). The later being a MUCH cheaper solution (~$5 each set).
    SIK99Tacoma likes this.
  3. May 10, 2011 at 9:55 PM
    Zombie
    Tucson, AZ
    That is quite possibly the most helpful reply I have ever had on a forum.
  4. May 10, 2011 at 11:29 PM
    LD PRERUNNER
    LD PRERUNNER Well-Known Member
    Larry
    West Covina
    2011 PreRunner SR5
    Alpine CDA-105 CD Receiver Alpine amp Polk Audio db6501 6-1/2" Component System Polk Audio db 651s 6-1/2" Slim 2-way Speaker Polk 10" sub-woofer 17" Sport Toyota rims Billy 5100 front & back Snug top AFE PRO dry air cleaner
    Zombie
    Was thinking about getting a Powered Subwoofer as well.
    Have you learned any more info?
    I just installed
    Polk Audio db 651s 6-1/2" Slim 2-way Speakers
    I am not happy, I want to add a 4 channel amp for the polks
    and some kind of subwoofer.
    Any help out their
  5. May 12, 2011 at 12:43 PM
    RAMZAK
    Mark
    Houston
    My pleasure!
    Please feel free to ask me any more questions you may have. PM me if you like
  6. May 12, 2011 at 12:46 PM
    RAMZAK
    Mark
    Houston
    If your adding an amp and all.... Go ahead and buy a 5 channel and use it for your 4-speakers and future sub
  7. May 12, 2011 at 1:04 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Is there a powered sub the fits under the front seats but still allows you to move the seats back & forth?
