Powertank Air Systems GB feeler
Discussion in 'Group Buys' started by The Traveler, Sep 5, 2013.
Thread Status:
Not open for further replies.
  1. Sep 5, 2013 at 10:58 AM
    The Traveler
    The Traveler [OP] Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I'm looking to gauge interest in Powertank Air Systems for the avid off-roaders on TW who don't have a solution to air up yet, or are unsatisfied with their compressor+tank setup. I know the compressors+tanks take a while to fill up 4 tires from 16psi to 32psi, so I started looking at the Powertank Systems. I've worked with these in person, and they are extremely high quality products.
    For those that are unfamiliar with them, basically, it's a scuba tank filled with CO2 that you can either leave mounted in the truck or bed, or easily remove and walk around with. They are very portable, and durable.
    Powertank offers a wide variety of sizes and packages, but the most common one for 33" tires would be a 10lbs tank. The 10lbs tank kit comes with the following:
    -Aluminum powdercoated Powertank 10lbs tank in many colors with sturdy handle
    -Tank pressure gauge
    -Superflow Pressure regulator
    -Super bracket for easy mounting
    -Tank boot
    -Tank cover
    -TIG-8200 Inflator (these things are awesome)
    -Tomco Super Coupler for easy coupling of air tools and lines.
    The above system goes for $509.95 retail. The 10lbs system is rated for up to 37" tires. With a 33" tire, the 10lbs system can inflate tires from 16psi to 32psi about 20 times before needing a refill.
    I will be getting one for myself, because I hate standing around my tire waiting for it to fill up after a long day on the trail. These things are much faster, more efficient, and much more portable in case a friend doesn't have a compressor.
    GROUP BUY PRICING GOES AS FOLLOWS:
    First 10 kits on order will get GB pricing of $449.95 SHIPPED. That's $60 off retail, and about $40 in shipping saved...so purchasing through the GB will save you $100.
    GB will be open until all 10 orders are placed.
    At this time, I can only do one part number at a time. The next GB will be for a different part no. depending on the interest and how this one goes.
    No need to wait for all 10 orders to be filled, just PM me to order.
    PM me with the following information:
    First+Last Name
    Phone Number
    E-mail address (to send invoice)
    Shipping Address
    Color of choice for tank anodize
    Please PM me with any questions. The invoice will be coming from my company at Rebel Off Road.
    Thanks!
  2. Sep 5, 2013 at 11:00 AM
    BytorTruck
    BytorTruck Well-Known Member
    Brandon
    Scottsdale AZ
    I think that would be a great group guy!!
  3. Sep 5, 2013 at 1:30 PM
    The Traveler
    SoCal
    Any others interested?
  4. Sep 5, 2013 at 1:35 PM
    AK 08TACO
    AK 08TACO Well-Known Member
    Kyle
    Wasilla, AK
    I would be interested if I could have it set up for Nitrogen
  5. Sep 5, 2013 at 1:35 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    very interested in a 20 lb tank setup.
  6. Sep 5, 2013 at 1:45 PM
    The Traveler
    SoCal
    We can definitely do different size setups for bigger tires, longer tank life, etc.
    I may even go for a 15 or 20lbs setup now that I'm running 35's.
  7. Sep 5, 2013 at 1:51 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    35s and air tools can eat up CO2. I also have the possibility of being relocated to somewhere fairly remote for my job, so if that happens, i don't want to have t struggle with finding a place to refill the tank. or at least not as frequently.
    FYI people, with the proper regulator or setting on the adjustable regulator, you can also run lockers off of CO2 tanks. you still need the electronics and though if you want to be able to control them on the fly.
  8. Sep 5, 2013 at 2:24 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
  9. Sep 5, 2013 at 2:35 PM
    OneWheelDrive
    OneWheelDrive Well-Known Member
    Peter
    San Diego/Encinitas
    2012 DBL Cab LB TRD Sport
    I'm in like a dirty shirt
  10. Sep 5, 2013 at 2:43 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    SUB'D FOR PRICE!
  11. Sep 5, 2013 at 4:36 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
  12. Sep 5, 2013 at 4:57 PM
    Az4x4
    Az4x4 Az4x4Taco
    George
    White Mountains, AZ
    '03 Tacoma TRD SR5 DC 4x4
    Deck Plate Mod, Grey Wire Mod, Vision Shell, Alpine Speakers and Amp, Sway-A-Way RaceRunner Nitrogen Shocks with Coilovers up Front, Deaver 8 Pack at the Rear with Bilsteins, All-Pro Rock Sliders, Cobra 29LTD CB, 800W Inverter, Constant 12v Power Outlet Mod, Open Door Warning Disabled, Garmin GPS..
    The idea is good, but the price seems through the roof! I have a 20lb CO2 bottle that I bought in the '60s and still use today. Paid $50 for it full, with a high pressure braided hose and tire attachment. Get it filled at my local fire extinguisher service and supply shop for about $30. Used to be $15, but that was then and this is now!
    Every 5 years I get it hydro-tested and recertified. It's gone everywhere with me and has always provided way more than I ever needed as far as refilling tires and such. Boats, RV's, trucks, trailers, you name it and it's never let me down. Fill it about once every three years now. Used to fill it once a year when we'd go to the beach in Mexico two or three times a summer.
    But like I said to start with, when the hell did a CO2 bottle - a baby one at that - get to the point of costing $500+!!!! ..Whew, dude! ..Glad I've still got old faithful!
  13. Sep 5, 2013 at 7:47 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    George, you can still part together your own CO2 kit for under $200. Amazon has 20lb tanks for about $100 last time i checked. sure the tanks aren't that different, other than a fancy powdercoat and the nice valve guard/grab handle, but there are other things taken into account. all of the accessories are designed with offroading in mind. Like Jasmine mentioned, it comes with the bracket, which is a top notch product. i've used both powertanks and home brew CO2 setups, and most of the home brews use regulators that are originally designed for welding or kegorator setups. the powertank hardware not only flows at higher CFM, but at the higher flow rates, you don't have the icing problems that you can have with the other regulators that are not designed with such CFM in mind. There are a number of other advantages built into the design and accessories of the power tank, but those are a few of the big ones.
    So the extra money we pay for a powertank or similar setup, like the smitty, goes into the extra measure to make the overall system a little more ergonomic and durable in an offroad environment. you just have to be the judge on whether the cost is worth the perks for your individual need.
  14. Sep 5, 2013 at 11:19 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Subd for price. Definitely on my 'to buy' list. Just gotta cross some other stuff off first. Can it be filled with nitrogen?
  15. Sep 6, 2013 at 9:30 AM
    Az4x4
    Az4x4 Az4x4Taco
    George
    White Mountains, AZ
    Here ya go! ..$67 for a 20lb tank freshly hydro tested and certified. Looks just like the one I've had with me everywhere I've gone since the '60s.. May not be as pretty as a high dollar one, but it'll do everything and more for a ton and a half less money!!!
    http://www.amazon.com/Steel-Recondi...&qid=1378484640&sr=8-3&keywords=20lb+co2+tank
  16. Sep 6, 2013 at 9:32 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    yep, that's the tank i was thinking of.
  17. Sep 6, 2013 at 5:02 PM
    FrustrationFabTaco
    FrustrationFabTaco Well-Known Member
    Luke
    Lexington, VA
    11 Duramax Grandpa Truck Special
    :spy:
  18. Sep 6, 2013 at 5:36 PM
    Camps
    Camps Well-Known Member
    Greg
    Bay Area
    21 TRD DC
    Fox, BR6, BAMF, SSO...
    interested to see what the price is for the GB
  19. Sep 6, 2013 at 5:47 PM
    rbraddock
    rbraddock Well-Known Member
    Randy
    Hampton, VA
    13 DCSB
    6" ProComp lift from the dealer, slow build in progress
  20. Sep 8, 2013 at 11:35 PM
    The Traveler
    SoCal
    Will get pricing up this week. Stay tuned! :)
Thread Status:
