Powertrax locker
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by dumontrider, Jul 23, 2022.
  1. Jul 23, 2022 at 10:41 PM
    dumontrider
    dumontrider [OP] Well-Known Member
    La Habra, CA
    14 GX460
    Selling a Powertrax No Slip locker, p/n 9220803001. Have been running this for about 20k miles without a single issue. Every tooth and chamfer are 100% good as new. This is not a LSD, this is what is commonly referred to as a "lunchbox locker". You can't turn it on like the e-locker or ARB. It locks your rear end when enough throttle is applied, I'd say around 15%. No pops or clicking around corners. A few times it's popped when reversing into a parking spot but otherwise it's seamless traction :burnrubber:
    https://www.amazon.com/dp/B00IVQQPQI
    Looking for $200 locally, $225 shipped.
    sold!
    Wulf likes this.
  2. Jul 31, 2022 at 3:31 PM
    dumontrider
    La Habra, CA
    14 GX460
    Bump! No air lines to leak, no need to rock back & forth to get it to engage. You press the skinny pedal & you have 2 tire fire. Zero maintenance aside from normal diff oil changes. And for 90% cheaper than other locker options!
  3. Jul 31, 2022 at 3:44 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    Curious why you chose this brand and how is the install? Or go to a diff shop?
  4. Jul 31, 2022 at 4:32 PM
    dumontrider
    La Habra, CA
    14 GX460
    I chose this because it didn't cost $2k+ like the air/electric alternatives & I didn't need a pro to install it. I don't have the tools to measure driveline lash so that also disqualifies me from DIY install of air or electric lockers. The hardest part of this install is removing the ring gear bolts, but if you have a jig to stop the diff from spinning....or use an impact gun....then it's cake. Once I procured a 1/2" impact gun to use (3/8" could maybe break em loose) the install took me about 2 hours, including reinstalling the 3rd member with Form A Gasket.
  5. Jul 31, 2022 at 4:40 PM
    AllTacosFloat
    Boston ish
    Great answers! I do have a few impacts. Can't recommend the Milwaukee 1/2" hi torque enough.
    Let me do a little reading on it but like the fact I could do it.... almost time to change the fluid too.
  6. Jul 31, 2022 at 4:52 PM
    dumontrider
    La Habra, CA
    14 GX460
    You mean this little girl right here? Yeah ...after borrowing it I need one. ASAP.
    AllTacosFloat[QUOTED] likes this.
  7. Aug 9, 2022 at 5:34 PM
    dumontrider
    La Habra, CA
    14 GX460
    Bump for 2 tire fire
  8. Aug 21, 2022 at 9:17 PM
    dumontrider
    La Habra, CA
    14 GX460
    Bump
  9. Aug 29, 2022 at 10:36 AM
    dumontrider
    La Habra, CA
    14 GX460
