Powertrax no-slip
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matic, Jul 29, 2010.
  1. Jul 29, 2010 at 9:30 AM
    Matic
    Matic [OP] The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Just purchased one. Looking forward to installing sometime tommorow.
    I think it will be a pretty good addition to my 4x2. I seem to be finding myself more and more on fire trails and rough areas looking for good hunting/fishing spots.
    From what I have read and researched, the powertrax no-slip acts more like a quadratrack than the other lockers that spool under acceleration and unlock in cornering and deceleration. So I think it is pretty much open diff until a wheel starts spinning and it shifts the torque to the wheel that has friction.
    I know there are tons of threads on this already but input on this particular unit would be greatly appreciated.
  2. Jul 31, 2010 at 4:40 PM
    Matic
    Tricky Dick
    Easley, SC
    ok. I would not recomend anyone doing that with just hand tools.
    Wouldn't have been so bad if I didn't have to remove the ring gear so that the pinion shaft could slide out.
    Up and runnin. Donutz in de yard. Woot!!
  3. Jul 31, 2010 at 4:52 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
  4. Jul 31, 2010 at 7:10 PM
    Matic
    Tricky Dick
    Easley, SC
    I think we all know what a rear locker looks like. lol.
  5. Jul 31, 2010 at 7:47 PM
    747 function > form
    1st Gen.
    pics or it didn't happen...
  6. Aug 1, 2010 at 11:54 AM
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Not the locker... If you mess around in your truck, pics are required. :D
  7. Aug 1, 2010 at 11:56 AM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    whats a locker?
  8. Aug 1, 2010 at 12:02 PM
    hoeflich
    hoeflich Its all mod on the inside
    florida
    96 3.4L 4X4
    Stuff
    Matic, congrats on the install, how hard was it? What was the part number for that? that was the 8" 30 spline?
  9. Aug 1, 2010 at 12:15 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    What do you mean by hand tools. What tools would you recommend? Air impact for the ring gear?
  10. Aug 1, 2010 at 2:25 PM
    Gtrsnax
    Gtrsnax Member
    S.E. Virginia
    2004 4x4 TRD
    I had one in my Wrangler for a while. I loved it. It rarely ever unloaded on the street and was johnny on the spot when I hit mud. Install was fairly easy once I realized the directions had one detail backwards. No additive is needed either, which is a bonus for trail repairs or whatever. If I was forced to go with a lunchbox again, that'd be the one I'd pay for.
  11. Aug 1, 2010 at 3:16 PM
    BRP27
    04 4X4 Tacoma SR5
  12. Aug 1, 2010 at 3:22 PM
    Killer
    Killer Well-Known Member
    Mobile, Al.
    98 4x4 TRD V6 3.4L SR5 XCab Gold with Tan Int
    19,000 Original Miles, Factory Alarm, Factory Tow Package, Low Profile UWS Black Tool Box, 20ft. of Dynamat Xtreme, Pioneer Double Din DVD 3200BT, IPod Holder, Q Form Kick Panels, 3 Pairs of MB Quart component speakers, JL Audio Stealthbox, Alpine PDX-5 amp, PIAA Foglights, WeatherTech Floor Mats, Maxxis Big Horn Mud Tires 32 x 11.5 R x 15, Wet Okole Seat Cover for 60/40 Bench, 5100's Front & Rear, Wheeler's Single Leaf AAL, Warn 8,000 Winch, Warn Transformer Brush Guard, Stebel Nautilus Compact Horn
    I have one of these on my Shelby Cobra replica. I bought it to make both wheels spin when doing burn outs.
    The only thing bad I can say after 5 years or so of owning one is that sometimes going around a curve it will disengage and make a loud pop noise.
  13. Aug 1, 2010 at 4:20 PM
    BRP27
    04 4X4 Tacoma SR5
    Which one did you install the Lockrite which pops and rachets or the No-Slip? The Lockrite No-Slip is different from the Lockrite. The no slip is made to trasition from locked to open smoothly.
  14. Aug 1, 2010 at 4:25 PM
    Killer
    Mobile, Al.
    I bought the No-Slip. But, you have to remember the Cobra is very light and you sit in an open environment close to the rear axle. So any noise or movement is felt very easy.
    I have a 9" Ford Rearend with 3.50 gears and 400+ hp. After 5 years the PowerTrax has had zero problems.
