Practical Lift Suggestions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shortbus47XYY, Nov 13, 2019.
  1. Nov 13, 2019 at 1:16 PM
    Shortbus47XYY
    Shortbus47XYY [OP] Well-Known Member
    Central Rockies, Colorado
    2017 TRD Off Road
    So I've been looking around at lifts lately and with so many options and so much that I don't know about what you really need for off roading I'd figure I'd ask for some practical advice.
    I'd like to be able to drive down trails without feeling like I need to worry. Ones that we have in Colorado like Black Bear, Imogene, etc. Are kindof what I'm referring to. But mostly this is a truck to get me to work during the week, and to a fishing hole or mountain biking spot on the weekend.
    Wouldn't mind it being a bit over built, but definitely not looking to break the bank. A kit around 1500 is probably my upper range. Around 1k to 1300 is probably the sweet spot.
    Any suggestions for this use scenario? Also, do you advise getting aftermarket UCAs?
    Thanks to everyone for reading and any suggestions.
    Ctupton likes this.
  2. Nov 13, 2019 at 1:26 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Bilstein 5100s
  3. Nov 13, 2019 at 1:36 PM
    Massappeals
    Massappeals Guest
    at 1500 get bilstein 6112/5160's
  4. Nov 13, 2019 at 1:36 PM
    Massappeals
    Massappeals Guest
    Also op didnt say how much lift he wanted, thats kind of important.
    Shortbus47XYY[OP] likes this.
  5. Nov 13, 2019 at 1:39 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    Can’t go wrong with old man emu but ucas are highly advised for proper alignment specs. I’d invest in sliders,skid plates, and good tires first.
  6. Nov 13, 2019 at 1:40 PM
    Shortbus47XYY
    2017 TRD Off Road
    That's a good point. I'd rather not go above 3" and face the challenges and extra work that comes with that. Really just want enough that I don't have to worry on the trails. Open to suggestions on height outside of that.
  7. Nov 13, 2019 at 1:41 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    OME kit with LR UCA's
  8. Nov 13, 2019 at 1:45 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    A simple aal, ome 887 coils with shock of your choice like ome or 5100s, and ucas would be a good entry setup you can upgrade as the truck evolves.
    I always think what good is lift if you hit a rock without armor it’ll happen just further down the trail.:notsure:
  9. Nov 13, 2019 at 1:45 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Find some people who will take out a noob with a stock truck. There are informal groups going out all the time. You can see what people carry on trails. A stock Tacoma is surprisingly capable.
  10. Nov 13, 2019 at 1:53 PM
    Shortbus47XYY
    2017 TRD Off Road
    Now that's a real good point!
  11. Nov 13, 2019 at 1:54 PM
    Shortbus47XYY
    2017 TRD Off Road
    That's definitely something to look into. Man, if it's doable stock it would be great to kindof figure out exactly what I need.
    MattCowsmasher likes this.
  12. Nov 13, 2019 at 1:54 PM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    My folks live just outside Montrose I’ve done imogene and engineer pass in my truck. A stock truck can do it with the right line choice.
    Go see what your comfortable with before spending money imho.
  13. Nov 13, 2019 at 2:10 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Full bilstein 5100s, 3 leaf AAL, SPC control arms for around $1300. Take 600 off that price if you won't be lifting more than 2" as you won't necessarily need UCA's although it doesn't hurt to have aftermarket if you're lifting the truck.
  14. Nov 18, 2019 at 5:44 PM
    nwflsr4x4
    nwflsr4x4 Well-Known Member
    Donny
    Pensacola Florida
    2019 White Tacoma SR
    I have an ‘19 SR 4x4 and was very surprised how capable a stock Tacoma performed off-road. Not sure about your tires, but I run 265-75-16 hankook dyna pro atm tires. There are better tires out there, but for someone who is on pavement 99.9% of the time, the lighter weight of the hankook will be better for your mpg. I went Jeep trail riding with Jeepers (bad idea) and eventually they found lots mud holes to go through. With less then 1000 miles on it I put my Tacoma through some pretty rough stuff. Clearance and larger tires from a lift might have helped on the one time I got stuck, but my tires were caked in clay and everyone had trouble on that one. The limited slip worked much better then I would have thought and is very capable even in a SR.
    https://youtu.be/alRcZAKYuNI
