Practical Tacoma Lift
Discussion in 'Suspension' started by Echodawg, Sep 12, 2013.
  1. Oct 21, 2013 at 7:32 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Dude, you're getting a $30k truck, talk them down $1,500 and get some Icons. All the other lifts will leave you disappointed. The stage 1 kit from Icon is a great entry level kit and will blow your mind with ride quality both on and off road. Keep the front at 2" and you won't need UCA's. It'll ride like a fucking caddie cruising through a jelly highway and much more controlled in all situations (take note that it's not stiffer but I also removed the sway bar). The other lifts suggested will essentially stiffen everything up similar to a spacer lift.
    In fact the first time a put my Icons on (was my 3rd different lift) I had a chubby the entire time I was hitting every pot hole, speed bump and irregular surface in the road I could and was giggly like a school girl it felt so good!
  2. Oct 21, 2013 at 7:50 AM
    Bosshoag
    Bosshoag Well-Known Member
    Mr. Doogan
    Virginia Beach, VA
    '20 4X4 TRD Off Road MT
    I'm here for knowledge folks, please feel free to inform me. Expedition Essentials Track Mount Weather Tech floor liners and window vents K&N air filter Summit Dakars in Matte Bronze -25 offset King suspension from Filthy Motorsports MESO customs white/red interior lights and MESO customs gasshole
    This sounds awesome. So does this Icon State 1 kit actually lift the truck at all or is it just stock height but better performance?
  3. Oct 21, 2013 at 7:50 AM
    azonicbruce
    azonicbruce Well-Known Member
    Bruce
    Owasso, OK
    2012 SR5 4x4 Double-Cab
    Another vote for Icon Stage 1 (if budget allows). Been worth every penny for me.
  4. Oct 21, 2013 at 7:55 AM
    azonicbruce
    Bruce
    Owasso, OK
    It lifts the front. You'll actually need to bring the fronts down a few turns to level it out. If you go with larger tires you're essentially getting a bit of an overall lift.
    With this setup you can still do some decent off-roading. At least enough to have a little fun. You can check out how this setup did here on my build thread:
    http://www.tacomaworld.com/forum/2n...2-dcsb-silver-streak-build-2.html#post7130961
  5. Nov 14, 2013 at 6:36 PM
    justchil
    justchil Well-Known Member
    Andy
    WV
    13 AC TRD OR
    Have you had any regrets not getting stage 2? Just curious... the $400ish would buy some other goodies... but on the other hand it would keep me from lowering the front giving an overall lift before tires.
    The terrain here is a little different so having that extra bit of height could really help me out I think.
