Praise T-SB-0062-18
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JimmySport, Aug 2, 2018.
  1. Aug 17, 2018 at 9:30 PM
    #321
    ToyotaRacingDevelopment
    ToyotaRacingDevelopment Well-Known Member
    Florida Native in Colorado
    '18 Tacoma TRD Off Road (Quicksand-Premium/Tech)
    Magnaflow Exhuast TRD PRO Grille w/ TSS Garnish
    Folks who got the 0062-18, are you saying that fixed other issues outside of WOT stumble? Such as downshifting hard on a slight incline?
    My tech told me today that the 0062-18 was only for WOT, but after reading some of the responses, it sounds like it fixes more...
    Blazingbluesport and Tig3r_Bit like this.
  2. Aug 17, 2018 at 9:31 PM
    #322
    Raker
    Raker Well-Known Member
    Northern Colorado
    2018 White DCSB TRD Off-road
    Awesome! My experience with the driving was pretty much the same. Smoother shifting, no lurching in down shifts, no crazy hunting for gears when good no up inclines... Feels like I’m driving a normal truck...
    rdjr17 and Tig3r_Bit like this.
  3. Aug 18, 2018 at 5:54 AM
    #323
    Tig3r_Bit
    Tig3r_Bit Well-Known Member
    2018 TRD OR 4x4
    Y'all are lucky! Took mines in. Dealership said they updated my truck. 0058. Got it back. Truck still rides the same. I called them back immediately and took it back in for them to look at. They called me and said
    Jerry,
    we have driven vehicle several times today and can not duplicate any issues with being sluggish or making noise, we checked for any new updates or technical service bulletins none found, also hooked up scan tool and no codes were stored in system, maybe need to ride with tech sometime, possibly next week ?. you can pick up truck anytime we are here til 6 P.M.Thanks
    --Robert Madich Luther Brookdale Toyota
  4. Aug 18, 2018 at 6:42 AM
    #324
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    So I wonder how much of the enthusiasm for this update is:
    A - placebo effect.
    B - resetting the active learning function.
    C - leaving the dealer with proper tire pressures.
    D - actual improvement.
    dangeroso and rickm like this.
  5. Aug 18, 2018 at 6:52 AM
    #325
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    A - Nope, definitely better. Just did a 1500 mile road trip prior to the update. Drove 70 miles of highway and city after. Speeds from 0 to 85 mph.
    B - Definitely a part of it. I’m going to drive it hard for the next 1500 miles just in case.
    C - Same pressure before and after.
    D - It’s better. The gas pedal is definitely more sensitive and much better throttle response, it actually uses 5th gear and can accelerate in it without dropping from 6 to 4. Accelerating on the on-ramp was better, holding gears in headwind on my way home from work was better.
    Really hope it holds up.
    Deathray, Carter'sTaco, Raker and 3 others like this.
  6. Aug 18, 2018 at 6:56 AM
    #326
    Tig3r_Bit
    2018 TRD OR 4x4
    Advisor said no code stored in system? Making me wonder if they even install the software the first time?
  7. Aug 18, 2018 at 7:19 AM
    #327
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    Have the tech put an obd2 meter on and tell you what the ECU calibration ID is. If it is not 04b0400 then it is not the latest update.
    Raker likes this.
  8. Aug 18, 2018 at 7:48 AM
    #328
    frodoz737
    frodoz737 TOP WRENCH
    Texas
    FWIW...I am a career Mechanic of more than 40 years.
    A. I drove the 2018 several times prior to purchase and was very aware of the WOT stall when cold at <500"ASL and searching gear issues...and the difference now.
    B. Resetting the battery (active learning function)...after one day on mine...not a valid point.
    C. Tire pressures do not effect factory programming.
    D. Actual improvement is in the eye of the beholder, but I can say with upmost certainty that T-SB 062-18 has made a major improvement in drive-ability. YMMV.
    Deathray likes this.
  9. Aug 18, 2018 at 9:58 AM
    #329
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    Took about 1.5 hrs. Got it done and it felt better. No complaints so far.
  10. Aug 18, 2018 at 10:23 AM
    #330
    Stocklocker
    17TRDORDCSBAT
    You missed my point. A lot of people drive around on under inflated tires, which robs the truck of performance. That’s what I was getting at.
  11. Aug 18, 2018 at 10:50 AM
    #331
    TacoBow
    TacoBow Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    ^^ The very reason I didn't buy a new one this year. Way too much pass the buck BS for a +$35K vehicle. I've owned (6) Taco's since 2001 and will not own a new automatic. Rant over. Now back to your regularly scheduled TSB discussion...
  12. Aug 18, 2018 at 11:14 AM
    #332
    rickm
    rickm Well-Known Member
    Rick
    MA
    2018 BLK Tacoma TRD Pro
    I don't understand I have a 4/18 build, I have no stumble, no jerky shifting, no gear hunting and no hesitation. I guess I can see the 16'/17' may have had some programming issues but people still having complaints with there 18'?
    In my case I'm not sure I would want the update.
  13. Aug 18, 2018 at 2:00 PM
    #333
    SilverTacomaGuy
    SilverTacomaGuy Well-Known Member
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    Little tree air fresheners. Clazzio black leather seat covers.
    Luckily when I was in for my 35k service today the dealer could not update it due to being to busy, as I was the only truck in the service department... and they would have to schedule me in at a later date. I'm roughly 200 miles away from 36k and I was told if I go over 36k before they can schedule me in then I'll have to pay for them to perform the TSB. With this Tacoma I've had the WORST experience out of all of my previous vehicles. Other vehicle companies are looking more and more attractive as the miles rack up.
  14. Aug 18, 2018 at 3:08 PM
    #334
    SD Quicksand
    SD Quicksand Well-Known Member
    Alex
    San Diego, CA.
    2017 Tacoma TRD Off Road 4x4 Access Cab Quicksand
    Have you read and printed out either TSB? They are posted here on TW. Both TSB's specifically state that this is part of the Toyota Emission Warranty and the coverage is 96 months or 80,000 miles. Time to educate your service writer....!!!!!!
    airborndad and Raker like this.
  15. Aug 18, 2018 at 3:56 PM
    #335
    SilverTacomaGuy
    Cody
    Central Oregon
    2016 TRD OFF-ROAD
    I had it pulled up on my phone. The more he spoke the more pissed I was getting.
  16. Aug 18, 2018 at 4:43 PM
    #336
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    Driven the truck for a lil over a year and I know for a fact that it made a difference right out the dealership lot. Rolling on from 40pmh to 60+ and I was never able to do this before. My truck is not stock either. Bumper, sliders, lifted, 285 tires etc. My commute to work has a lot of ups and downs and it drive so much smoother
    https://youtu.be/s9WjW2UFa0Q
    Psi is at 36-37PSI
  17. Aug 19, 2018 at 9:43 AM
    #337
    sigrude
    sigrude Well-Known Member
    Northern CA
    2018 Cement TRD Off Road DCLB 4X4 AT
    I just dropped the truck off at the dealership. The service advisor stated they will take it for a test drive and go from there. Crossing my fingers.
  18. Aug 19, 2018 at 11:37 AM
    #338
    sigrude
    Northern CA
    Well, I waited two hours at the dealership. Service tech took it for a ride and wasn’t able to replicate the problem (I complained that the truck struggles going up hills). Service Advisor stated there are no updates. I showed him the TSB 0062-18. He took it somewhere and came back. He stated that it is only for high altitude area and they won’t be able to replicate it. Time to find another dealership.
    Tig3r_Bit likes this.
  19. Aug 19, 2018 at 11:39 AM
    #339
    oscolivar1
    Oliver
    VA
    2017 Tacoma Limited
    Show them TSB-0058-18 and itlll get done.
  20. Aug 19, 2018 at 11:57 AM
    #340
    sigrude
    Northern CA
    I showed the Service Advisor both TSBs and he stated the 58 only applies to the 2016 and 2017 models.
    Tig3r_Bit and oscolivar1 like this.
