Pre '01 grille
Discussion in '1st Gen. Tacomas (1995-2004)' started by glwood6, Jan 10, 2009.
  1. Jan 10, 2009 at 9:43 AM
    glwood6
    glwood6 [OP] Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    Is there any way to retrofit the pre '01 grille to the '01-04 Tacos? The only thing I don't care for on my '02 is the vertical slats on the grille setup. I've considered going to a billet type, but really don't care for them all that much. If one of the earlier cannot be retrofitted, I guess I will have to come up with something on my own...
  2. Jan 10, 2009 at 9:44 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    you could...but you'd have to change the fenders and hood too...and headlights...the entire front clip basically
  3. Jan 10, 2009 at 11:47 AM
    glwood6
    Gary
    Albuquerque, NM
    Well, that shoots that idea. I'll see what I can come up with.
  4. Jan 10, 2009 at 6:40 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    I'll trade you front ends.
  5. Jan 12, 2009 at 9:54 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Have you considered a mesh or expanded metal - style grille insert?
  6. Jan 12, 2009 at 3:33 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    im making a grill for my taco now its fiberglass and im going to do a black mesh insert.its the shit.
  7. Jan 12, 2009 at 4:56 PM
    glwood6
    Gary
    Albuquerque, NM
    The thing is, I like the materials the stock grill is made out of, ie. the bars (plastic), I just like it when grilles run horizontal instead of vertical. If I can find the right material, I'm going to come up with something. I like the honeycomb mesh look behind solid bars, that's the look I'm trying to achieve.
  8. Jan 13, 2009 at 9:20 AM
    SRFIVE
    SRFIVE Well-Known Member
    Upstate NY
    '04 SR5 TRD DC
    Keep us posted, it sounds good, will you go deep dish style too? Closest thing i have seen is the custom Satoshi grille.
  9. Jan 13, 2009 at 8:06 PM
    Hambone155
    omaha
    use a black micro mesh. look it up and the way to mount it is pretty simple. what i thought of is when you cut out the bars find a spot you can run the mesh peice too and when you do so epoxy a bolt to the plastic part of the grill then drill a whole in the mesh and bolt it up.
    does any one get what im saying. im sure if i drew it out it would be even simpler.:)
  10. Jan 13, 2009 at 10:06 PM
    glwood6
    Gary
    Albuquerque, NM
    This is the look I am trying to achieve, or something close; I'm not trying to make my Tacoma look like a Tundra, I just like the grille layout better:
  11. Jan 15, 2009 at 3:27 AM
    dustinuhls
    dustinuhls Well-Known Member
    Manhattan, KS
    '01 Limited DoubleCab 4x4
    3" SL, Nerf Bars, 33" BFGs, K&N, Deckplate, Royal Purple
    I personally like the grill of the '01-'04s. Maybe not just the grille, but the whole front clip. I had a pre-'95 Toyota Truck and hated the Tacoma when they first came out. Once they added the new-look front clip in '01 I loved it. I'm also like you and don't like the billet grille look. I like the "chunkier" grille sections that our trucks have. I would, however, like to see if you could come up w/ something like that Tundra grille pic. That might actually be kinda cool. Post some pics if you ever get it done.
