Pre-assembled OME install
Discussion in 'Suspension' started by bisontaco, Jul 29, 2013.
  1. Jul 29, 2013 at 10:19 PM
    bisontaco
    bisontaco [OP] Member
    canada
    07 trd sport
    I have done my due diligence by using the search function, but I'd really appreciate a clear answer from someone in the know.
    I am going to be installing a re-assembled (used) OME 885 set up tomorrow. i have found countless information on the non-assembled install. Is the pre-assembled install as simple as, remove the top three bolts, remove the LCA bolt, replace, torque to spec, and align? or do I have to remove the lower ball joint? Much appreciated, will get pics up tomorrow.
  2. Jul 29, 2013 at 10:21 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    you are correct! if the coil is already assembled on the strut, then removing the 3 outer top nuts and lower bolt is all you need to do. leave the upper nut in the center alone. an alignment will be needed. no need to remove or do anything with the lower ball joint.
  3. Jul 29, 2013 at 10:22 PM
    davidjmay
    davidjmay Well-Known Member
    David
    Orange County/Azusa
    '00 PreRunner
    Pioneer HU & door speakers, Alpine type R, Kicker dx1000.1, OME 883 lift, Wheelers 2" AAL, custom mesh grille, smoked LED taillights, LED light bar, Raptor exhaust dumped before axle, custom fabbed roll bar/light bar mount
    Yup
  4. Jul 29, 2013 at 10:24 PM
    bisontaco
    canada
    07 trd sport
    Thanks! i have found the correct torque spec for all but that upper middle nut. Any idea? does it matter?
    Oh, and is it still required to remove the swaybar?
  5. Jul 29, 2013 at 11:01 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
    Still remove the sway. And not sure about the middle nut but i thought it came pre assembled?
  6. Jul 30, 2013 at 12:01 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    Disconnecting the sway bar from the knuckle will just get you more room to play with.
    Torque specs for the middle nut is 20 lbs/ft/.. BUT... I thought they were already pre-asseembled?? Are you just wanting to check on it? Hand tight is good..
  7. Jul 30, 2013 at 3:52 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
  8. Aug 2, 2013 at 7:56 PM
    bisontaco
    canada
    07 trd sport
    Thanks for all the help you guys. I successfully (with great difficulty getting every piece removed and installed) installed a 2.5'' ome front lift with 885's. And icon progressive add a leaf's (leaves?) in the rear. I am very pleased with the look, but more pleased with the performance. I just purchased this truck used two weeks ago and my mods thus far are, blacked out lower valance, removal of the hideous roof rack, and currently tinting the three taillights. The first picture is a BEFORE picture, I think my rear leafs were shot, because it was really low in the back.
  9. Aug 2, 2013 at 11:38 PM
    davidjmay
    David
    Orange County/Azusa
    '00 PreRunner
  10. Aug 4, 2013 at 10:18 AM
    raycie
    Oahu, HI
    In need of $$$
    Fyi... you may need new UCAs after.
  11. Aug 4, 2013 at 10:21 AM
    medic2230
    Murph
    Bama! Roll Tide
    Shouldn't have to with 2.5.
  12. Apr 9, 2014 at 6:59 PM
    CO Taco
    CO Taco Well-Known Member
    Tyler
    Seattle,WA
    ‘25 SR5 4x4 Black
    Clazzio Seat Covers Black badge overlays All weather floor mats Glass navigation screen protector
    nice job! hope i can do this myself as well.
    Looks like the need of UCAs is pretty contested at 2.5. If he were able to fit the shocks in then he may be ok
