PRE Black Friday HID GB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kustom54lighting, Nov 15, 2017.
  1. Dec 13, 2017 at 8:32 PM
    #161
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    My issue is that it seems some of the plugs are the same so I can't tell by prewiring it what exactly goes where. I haven't spent much time on it though. I ordered the relay with the harness as well. Tomorrow is a new day, we will see how it goes.
  2. Dec 14, 2017 at 7:24 AM
    #162
    TacoLpastor
    TacoLpastor Well-Known Member
    NC
    2016 DCLB OR 4X4
    I have this kit on the relay harness. Perhaps it is unrelated, but my battery has been dead the last two mornings. Does this kit draw any power when the truck is off, with the relay harness?
  3. Dec 14, 2017 at 9:00 AM
    #163
    Lt. Dangle
    Ohio
    Question on the "OEM input" on the relay. I have one oem connector, yet 2 headlights... What is the setup for that? The instructions on the site aren't helpful. Thanks.
  4. Dec 14, 2017 at 9:02 AM
    #164
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Just plug one OEM connector into the plug on the ballast and leave the other unplugged. The oem connector is just a switch to trip the relays into powering on the ballasts.
  5. Dec 14, 2017 at 9:12 AM
    #165
    Lt. Dangle
    Ohio
    Doing that I have no low beams. I'm gonna recheck my work. Thanks for the info.
  6. Dec 14, 2017 at 9:17 AM
    #166
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    The harness is tagged as to where each connector goes, only one oem headlight plug is required, the one by the battery. Then plug the two new harness plugs into the ballasts, then ballast to igniters, then igniters to new hid bulbs.
  7. Dec 14, 2017 at 9:17 AM
    #167
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Correct polarity / clips pushed in all the way? Some of those are gnarly to push in. Low beams are the ones you're replacing w HID right?
  8. Dec 14, 2017 at 9:57 AM
    #168
    Lt. Dangle
    Ohio
    Yeah to all that.
    I'm a big dummy.
    There is a 8" long piece that goes from the OEM switch to the harness that I left on the intake... Turns out it is kind of important.
    Thanks for holding my hand lol. Now I'm trying to figure out where to mount it all so the harness stretches far enough.
  9. Dec 14, 2017 at 9:57 AM
    #169
    Lt. Dangle
    Ohio
    Yeah the other OEM switch tripped me up. Thanks.
  10. Dec 14, 2017 at 11:13 AM
    #170
    Skydvrr
    Nick
    YMH
    Black '17 OR
    @Lt. Dangle I made a cheesey aluminum plate with a tab bent over the top at 90* that attaches to the battery hold down. It holds one ballast, both relays and one double sided taped ignitor. Seems to be okay for now.
  11. Dec 14, 2017 at 11:35 AM
    #171
    Lt. Dangle
    Ohio
    I mounted a ballast and the relays to the inner fender area besides and in front of the battery. The ignitor is just zip tied to the mess of wires. On the passenger side I would have killed for longer wires. I had to mount the ballast next to the radiator. Ignitor zip tied again. Longer wires would have let me run it around the back of the engine compartment with the factory look like I wanted to. I might look into it again come springtime.
  12. Dec 14, 2017 at 12:28 PM
    #172
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I feel ya. Same thing! I had to mount mine next to the radiator with a couple of existing holes. I was lucky enough to be able to double sided tape my igniter tho.
  13. Jan 7, 2018 at 12:03 PM
    #173
    TacoLpastor
    NC
    2016 DCLB OR 4X4
    I have one bulb that does not always ignite. I have to turn my lights on and off a few times before it starts up. Is this related to a bad igniter?
