Pre-collision malfunction, vsc
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Truckgurl4life, May 27, 2024.
  1. May 28, 2024 at 12:45 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    Your WDH needs to be set up better. You should be able to get even clearance front to back within the wheel wells. What brand WDH do you have?
    Oh and bump stops don't take all day.
  2. May 28, 2024 at 12:47 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Firestone bags, E-trailer.
  3. May 28, 2024 at 12:47 PM
    fxntime
    Prices are decent, the bags have been around awhile.
    Truckgurl4life[OP] likes this.
  4. May 28, 2024 at 1:03 PM
    Truckgurl4life
    Truckgurl4life [OP] Member
    2021 tacoma
    I will have to check the weight distribution hitch for the name, but I know the rv place where I bought the trailor put it on truck
  5. May 28, 2024 at 1:13 PM
    Truckgurl4life
    2021 tacoma
    Does the lights warnings come off on their own, and is it dangerous to.pull trailer without air bags, and will it damage the truck
  6. May 28, 2024 at 1:20 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    The warnings lights should come off without loaded, if they don't, you have other issues, but I think your trailer setup very well may be the culprit.
    Bump stops are only engaged when bottoming out,, you don't want to be on them, this is a sign of being overloaded and/or improper springs. Air bags will help out a lot in this case, you can fill them when trailering and empty them when not, for a smoother ride. Of course this means filling and emptying them. There are kits made that you can wire and plumb in, so you can fill and empty from the cab.
    As mentioned, you still need to properly weigh this setup and an adjust your WDH.
    In the end, while it is doable, that trailer is not light weight. It is on the heavy side and has a ton of drag on the lil (not so good at towing) Tacoma, so go in to this knowing that. I would seriously weight out costs of modifying your truck versus trading in for a full size truck.
    GL
    BlackTRD4Me likes this.
  7. May 28, 2024 at 2:08 PM
    TacoSupremo19
    NJ
    I tow a slightly bigger travel trailer. I have a Add a Leaf (3 leaf) from Icon which I also kept the OL leaf in place. I was able to get an even load front to rear by adjusting the WDH per the instructions but you are still within the specs of the GVWR so it should adjust. I also have Duro Bump stops and also have a tune. Honestly, I think I could tow more but I know better.
  8. May 28, 2024 at 2:33 PM
    Truckgurl4life
    2021 tacoma
    What is a tune, somebody told me that air bags are no good, and that leaf springs are better, im so confused and frustrated
  9. May 28, 2024 at 2:39 PM
    fxntime
    The air bags are used in conjunction with the leaf springs already in place. A tune is modding the shift points or engine tune to produce different shift points or a little bit more power.
    Adding more leaves to the original springs can decrease the the sag but usually at the expense of a harsher ride or a more raked [raised rear] look when not hooked up to a trailer.
  10. May 28, 2024 at 2:45 PM
    Truckgurl4life
    2021 tacoma
    My husband too has a tacoma 2020, was wondering maybe trading it in for a bigger truck would that solve the problem lol
  11. May 28, 2024 at 2:45 PM
    Truckgurl4life
    2021 tacoma
    But we do love our tacomas
  12. May 28, 2024 at 6:15 PM
    Truckgurl4life
    2021 tacoma
    Another question, does the Weight of your truck, is added to the weight of the trailor
  13. May 30, 2024 at 9:26 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    see my post #6, they are screenshots from the Toyota owner's manual, explaining the different acronyms which you will also find your exact numbers on the sticker in the driver's door jamb. Each vehicle is slightly different, as they are outfitted with different options. Additional options add weight, thus reducing capacity.
  14. May 30, 2024 at 9:31 AM
    Pungo1
    Pungo1 Well-Known Member
    Mark
    Right? Me: "but there's about 2 quarts of oil on the garage floor under my truck" Dealer: "normal operation.....don't worry about it".
    BlackTRD4Me[QUOTED] likes this.
