pre-collision system malfunction - visit dealer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cmt_taco28, Aug 12, 2021.
  1. Oct 13, 2022 at 5:51 PM
    #41
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    There is a amber PCS off light that is lit all the time yes
  2. Oct 13, 2022 at 7:24 PM
    #42
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    I had a very similar situation after installing the Eibach 2" lift & Pro grill (figured the height change would offset each other) on my 2020 about 2 years ago. All the dash lights were on. The alignment took care of the zero point recal reset and that fixed 1 light. Took it to the dealer to reset the TSS only option. They had it for 4 days, the tech went through the process... new TSS harness, new TSS sensor, etc but still had the error. Day 4 they brought the senior tech over, they even had me come in to unlock/remove my trailer hitch so no obstructions. They had plump bobs hanging from all sides of the truck and a weird graph chart thing on the wall in front. He fixed it in a just a few minutes after that. He said all the angles for the yawl, axis, etc needed to be set properly prior to resetting it.
    Bottom line - it can be fixed by the dealer, looks like a lot of work to me so maybe that's why some say no??
    H3llRid3r likes this.
  3. Oct 13, 2022 at 7:42 PM
    #43
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    There is a TSB for the radar sensor to be replaced because it can get water inside and eventually cause malfunctions. So anything related to that center "garnish" sensor leaking or moisture inside can be done via TSB.
  4. Oct 13, 2022 at 8:42 PM
    #44
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    I wonder why the Lane Departure and Auto Headlight would be related to the radar in the grille? Why three separate codes?
  5. Oct 14, 2022 at 4:51 AM
    #45
    NorrinRadd
    WA
    I have no sensors in my rear or front bumpers (because I replaced them with actual steel) and I still have lane departure available. I keep it turned off since it's so annoying when I drive home after having a few drinks. (j/k) : - )
    Have never played with the auto headlights but those are triggered by the dashboard light sensors near the dash speakers I believe. Don't know what to tell you about the codes the ECU throws, those are created from the minds of Japanese engineers...
    H3llRid3r[QUOTED] and auskip07 like this.
  6. Oct 14, 2022 at 9:05 AM
    #46
    stftaco
    stftaco Well-Known Member
    22 MGM DCSB Tacoma TRD Sport
    Might I have read somewhere that led brake lights when they fail can cause this? I thought I saw this in another thread somewhere???
  7. Oct 14, 2022 at 11:39 AM
    #47
    H3llRid3r
    SLcUT
    Interesting. Someone else asked if I had after market headlights and taillights. I guess it would be to straightforward to have a separate code for taillights.
    stftaco[QUOTED] likes this.
  8. Oct 14, 2022 at 12:29 PM
    #48
    stftaco
    It could be intentional, not sure. These vehicles are getting so "Control-Module" centric, that I imagine there's a lot of software programming / code, and well, sometimes all paths through that software are NOT tested. Bulbs with filaments fail nicely, as an open circuit. LEDs sometimes fail open, closed, or high resistance. I like how others here always ask posters, what mods, what was the last thing changed? That's a good place to start.
  9. Oct 14, 2022 at 3:14 PM
    #49
    H3llRid3r
    SLcUT
    That’s the thing. The truck was sitting in the Park ‘n Jet for four days. It’s heavily moded, but that was 50,000 miles ago. No recent changes.
  10. Nov 8, 2022 at 9:15 AM
    #50
    Amorak
    Amorak Well-Known Member
    2021 Magnetic Gray Metallic Tacoma TRD OR DCSB Premium
    I'm having seemingly random TSS pre-collision issues. Usually start after hour + driving, then goes in and out (sometimes warning is on for only 3 minutes, others for 25 minutes then goes off again?), again, randomly. What are the symptoms to indicate "water"? Mine is a 2021 - I couldn't find the TSB thru google - does it apply to '21's still?
  11. Dec 3, 2023 at 8:24 AM
    #51
    jckinnick
    jckinnick Well-Known Member
    Tn
    2002 Toyota Tacoma TRD SR5
    None
    Mine started doing this out of nowhere trucks pretty new got it lifted at the dealership with the factory lift and pro grille about a month after I bought it back in August and it just now started giving me the warning I haven't been in any wrecks
  12. Dec 3, 2023 at 12:17 PM
    #52
    hwntaco20
    Might just need to clean the sensor cover on the grill.
  13. Nov 8, 2024 at 12:04 PM
    #53
    diamondsintheskye
    diamondsintheskye New Member
    2019 Tacoma TRD Sport
    2" lift with brushguard and winch
    Could I get some help with this? I've bought this code reader, updated the firm ware and paired the app with the device and it is still telling me there are no codes or errors even though my dash has the pre collision system malfunction message and light lit up.
  14. Nov 8, 2024 at 12:22 PM
    #54
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    The pre collision system malfunction could be a few different things. The scan tool I recommended was to reset zero point calibration. That won't help you if you have a sensor issue, bad calibrated sensor or some wiring damage. What caused the light to come on?
  15. Nov 8, 2024 at 2:49 PM
    #55
    diamondsintheskye
    So I noticed that the light for the pre collision system would come on and the display would say the sensor needs to be cleaned when I was 4 wheelin. It would always go away after restarting the car, washing it or sometimes on its own. Then last week I was 4 wheeling in some heavy rain and it came on but this time said pre collision system malfunction and has not gone away. Two things are at the top of my list as possible causes. First is that the truck was modified before owning it, so it has a lift and aftermarket brush guard and grill. The grill doesn’t have a cover for the sensor and I noticed that the sensor was moved and just zip-tied to the grill. I’m guessing the metal from the brush guard and lift were causing problems with the sensor and is why it was moved. Second I did notice that the wiring was exposed near the connector to the radar sensor. I’m not loving that and would really like to replace that either way but unsure of how to go about that. Is there a semi cheap scanner that can read those codes to find out exactly that is wrong, or should I bite the bullet and take her to the dealership who’ll probably tell me that it’s been modified and there’s nothing they can do?
    Superdave1.0[QUOTED] likes this.
  16. Nov 8, 2024 at 4:12 PM
    #56
    Superdave1.0
    SoCal
    Does the brush guard obstruct the sensor at all? The sensors don't like anything even close to in front of it. Has to have a clear sight of view.
    The sensor being zip tied and the wiring being exposed are going to be your issues. Can't just have the sensor zip tied there. I would be looking for a used takeoff grill, with sensor preferably. Maybe on ebay or a junkyard. Can check car-part.com as well.
    For the wiring I'd be looking for a new or used pigtail to splice in. Taking this to the dealer is going to cost a fortune. With a new/used sensor it might require calibration with specialty tools and targets.
    #56
  17. Nov 8, 2024 at 4:15 PM
    #57
    Superdave1.0
    SoCal
    Regarding the scanner, did you get into the ABS menu when checking with the Innova scanner?
    A more sophisticated scanner that can read that sensor code would cost several hundred if not thousands. Unless there is a reliable one out there that I'm not aware of.
  18. Dec 11, 2024 at 7:53 AM
    #58
    Kenshaw720
    Kenshaw720 Member
    Ken
    2020 Tundra TRD Sport
    King Shocks, BAM Muffler, Method Wheels, Falken Tires (305/65/18), Pioneer HU, Miiler Cat Cat Shield
    Back story (I have Techstream and the Tactrix cable so I am good on the scanner side) - I replaced my steering wheel and had issues with all sorts of warning lights. I apparently f'd up the steering wheel sensor somehow (it's attached to the clock spring). I tried an aftermarket sensor. It cleared all of the warnings related to the steering angle but it would never initialize. I even talked to the service mgr at the local Toyota dealer. He printed out the same info I got from the TIS database on how to clear and initialize the steering angle sensor. He said I was doing it correctly so we figured it was the aftermarket sensor. I caved and bought an OEM one and it solved all of my code issues. I am still getting the Pre-Collision malfunction but Techstream can't find any codes. I've read about codes being stored so they don't show up as a code in either the current or history category. TIS has a 2 day subscription (Techinfo.Toyota.com) that has all of the data the dealers have access to. I used that at the beginning of this whole mess. I'm going to get another 2-day subscription to see if there is a solution to this before messing with the actual sensor.
