Pre-Collision System Malfunction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by soggyBottom, May 28, 2024.
  1. May 28, 2024 at 3:01 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    After hitting a massive pot hole, I got 2 errors pop up on my dash. There are no engine codes. How can I troubleshoot what the problem is? Here are the 2 errors.
    And
    Check Vehicle Stability Control System
  2. May 28, 2024 at 3:08 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
  3. May 28, 2024 at 3:11 PM
    soggyBottom
  4. May 28, 2024 at 3:21 PM
    Clearwater Bill
    Billy
    Largo Florida
    Circular linking error. :D
  5. May 28, 2024 at 3:27 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    We're stuck in a worm hole captain!
  6. May 28, 2024 at 4:13 PM
    HighIronHooligan
    HighIronHooligan TW Misfit
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    A while back I got the same two messages on the screen.... ended up being because the u bolts on the rear axle were loose enough that the axle shifted about an inch to the passenger side.
    soggyBottom[OP] likes this.
  7. May 28, 2024 at 4:20 PM
    soggyBottom
    I did recently install add a leafs. How did you reset the codes?
    BTW, the code is C1A50 "Brake System Malfunction".
  8. May 28, 2024 at 4:35 PM
    HighIronHooligan
    Paul
    Tucson, AZ
    2022 MGM OR DCSB MT
    I went to the dealership I bought the truck from and the fix was covered by the warranty.
