pre filter bag
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SIK99Tacoma, May 3, 2025.
  1. May 3, 2025 at 10:57 AM
    SIK99Tacoma
    SIK99Tacoma [OP] Well-Known Member
    Taylor
    Big Sur
    2020 OR DCLB
    FOX IFP front 2nd clip 1/2" spacer, FOX 2.0 adjustable resi rear, RXT leaf pack, SSO slimline front w/ baricade 9500lb and amber light bar, ARE Cap, allpro steps, TRD pro style wheels w/ Kenda Klevar skins
    Im thinking of adding a pre filter bag to the inlet on the filter box, siliconized Rough Country cold air style, as a pre screen before the oem filter. I live on a super dusty CA dirt road. I have an idea how I want to do it, they are only 10-15$ and they are supposed to not limit air flow.
    Question for cold air intake folks do you use the pre filter? does it help with fine dust mitigation?
    They seem to be useful keeping some dust out of the paper filter on our quads and dirtbikes, though those are the foam style not the bags
  2. May 3, 2025 at 11:07 AM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    Anything that actually filters dust is going to limit airflow, and anything that doesn't limit airflow isn't going to filter dust.
    I would just change your filter more often if I were you.
    OZ TRD, Tacosha, soundman98 and 2 others like this.
  3. May 3, 2025 at 11:42 AM
    eurowner
    eurowner Duke Sky
    Scoty
    https://www.roughcountry.com/cold-air-intakes/toyota/tacoma/2019
    Well, if you removed the OEM Tacoma true cold air intake box that uses the same V8 Tundra air filter, you have an inferior air filter setup, and you probably should use the filter screen.
  4. May 3, 2025 at 7:25 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    one of the cyclone pre-cleaners on a snorkel seems ideal for that use case.
    SIK99Tacoma[OP] likes this.
  5. May 7, 2025 at 10:34 AM
    SIK99Tacoma
    Taylor
    Big Sur
    2020 OR DCLB
    not removing the OEM filter box or filter.
    on the inlet to the oem box adding a fliter bag. 3d printing an adapter for the inside of the box, bag just lays inside the box just below the oem filter. catches dust on the inside
  6. May 7, 2025 at 12:41 PM
    Veet-88
    Veet-88 Well-Known Member
    18 Tacoma DCLB sport
    This is the way it works like a hop damn for combating dust.
