Pre-Made Satoshi Grille Piece Group Buy
Discussion in 'Group Buys' started by HomerTaco, Mar 18, 2011.
Thread Status:
Not open for further replies.
  1. Mar 20, 2011 at 9:46 AM
    #41
    timsxr
    timsxr Well-Known Member
    portland
    I might have missed it, in the mold did you add tabs for people to screw the mesh to so they don't have to glue or ziptie???
  2. Mar 20, 2011 at 9:47 AM
    #42
    HomerTaco
    HomerTaco [OP] Grill Sergeant Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    Will get to all questions & update list late this afternoon/evening...
    Doing charity walk for cancer today in Philly with the family.
    Thanks!:D
  3. Mar 20, 2011 at 9:48 AM
    #43
    ronny97
    ronny97 Taco Madre
    Ronny
    Dickinson, TX
    White TRD Sport
    I am so in. I've been in since you started the first thread. I didn't get on the forum yesterday so I missed alot. What a surprise that this has turned into a GB. Thanks so much for doing this. I hope this runs smooth.
  4. Mar 20, 2011 at 9:49 AM
    #44
    gatlin69
    gatlin69 Retired?
    Scott
    Tampa
    4x4
    Nerf bars, bug shield,skid plate, coming soon (hopefully) DVD NAV
    Good on you... :thumbsup:
  5. Mar 20, 2011 at 10:03 AM
    #45
    robstaco35
    robstaco35 Well-Known Member
    Rob
    Cape Cod
    Tacoma SR5
    Count me in! , will want the mesh too.
  6. Mar 20, 2011 at 1:09 PM
    #46
    HomerTaco
    Craig
    Bucks County Pa.
    The prototype is my Satoshi insert off of my truck and is pictured from two different angles on the first post. The final product will look like this.
    I wish I could give you an exact answer... The Reduced Depth will have to be done by hand & I'm a perfectionist.. I'll have to ask you to wait until I have the final product to use one as a guinea pig.:rolleyes: best guess: $25
    Yes, that is the plan.
    The final product will look exactly like the grill in my current sig pic. I have aluminum mesh installed.:cool:
    The Install will be as painless as possible! That is the real point of this whole endeavor is to make the mod less complicated. The actual removal of the insert took less than 5 minutes with a dremmel tool.
    Keith, hang in with me on this. I need to see what the manufacturer is able to produce on the mold. I originally intended to have mounting hardware included but that was before I knew more about the actual process of manufacturing.
    I will say this: My grille (with is now disassembled) was held together using the zip-tie method & was strong as all hell. I'll have a firm answer on this Tuesday when I drop off the Prototype.
    Yes the insert will be black. I see no reason why Tim's grill wouldn't work on the insert... From the pics in his GB it looks like it screws right into it. (really slick looking too..)
    Order matching paint & spray it yourself or pay a body shop to do it.
    Will have pics up hopefully Monday, but no later than Wed. next week!:thumbsup:
    see my answer to Keith above. BTW - your grilles & light bars are badass!:cool:
    Thanks for all the input & patience on this project!
    as of now we are halfway to the goal for the first run of 50.
  7. Mar 20, 2011 at 1:57 PM
    #47
    dkbigbuds
    dkbigbuds Well-Known Member
    so cal
    2.7L tacoma white on black
    that sounds like a good ballpark to me... sign me up mesh too!! any way i can get a little extra mesh for the bottom valance too?
  8. Mar 20, 2011 at 2:14 PM
    #48
    DevL
    DevL Well-Known Member
    I will buy when...
    Mesh is as quality, strong and able to transmit light (not thick for max light transfer). Available for the main piece and triangles.
    Half depth Satoshi you stated youd be making in limited quantity.
    When those are lined up I am buying... and not untill.
  9. Mar 20, 2011 at 2:17 PM
    #49
    KodiakVA
    KodiakVA Well-Known Member
    Richmond Virginia
    09 4x4 XCab Sport BarcelRed
    You the man!!
    Count me in. Just tell me how you would like to get the money and I'm on it. USPS Money order works best for me and is very safe for you.
    Also if I can throw in my 2 cents. I would like to see some substantial tabs on the outside of the interior section of the center section and outer triangles. These tabs could be used to tap into for securing the mesh to the frame. If they were each of a substantial size a person can align the holes of the mesh with the tabs for perfect placement. If each tab has a large surface area this piece could easily handle many different meshes without issue. So while there may be more Satoshi's the many different mashes will make each a little more unique. Also changing meshes will be a snap.
    Thanks again and just say when you need the dough!
  10. Mar 20, 2011 at 2:22 PM
    #50
    timsxr
    portland
    Put me down for one so I can test fit my grills.. It will be nice even on front mount grills ie grillcraft and my front inserts so when you look behind the mesh it won't be all cut up!!
  11. Mar 20, 2011 at 3:23 PM
    #51
    HomerTaco
    Craig
    Bucks County Pa.
    I plan to offer an option for that as well - more info this coming week.
    got it. totally understandable. stand by for more info.
    ^^^this post^^^ is EXACTLY what I have in mind but will not know until my meeting with the manufacturer on Tues.
    I know how to attach with the zip-tie method but I was hoping for something better. With the injection mold, anything is possible, with vacuum form there are limitations...
    once again... stand by...
    you bet!:thumbsup:
  12. Mar 20, 2011 at 4:10 PM
    #52
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    Put me down for the reduced depth version.
    how big will the lip be? I would like about 3/4 to 1" for the depth
    Justin
  13. Mar 20, 2011 at 5:48 PM
    #53
    dkbigbuds
    so cal
    cant wait!!!
  14. Mar 20, 2011 at 8:22 PM
    #54
    MC1983
    MC1983 Well-Known Member
    Mark
    Indianapolis, IN
    2005 DC LB PreRunner Sport
    Put me on the list. Would local pickup be available as well?
  15. Mar 20, 2011 at 8:43 PM
    #55
    HomerTaco
    Craig
    Bucks County Pa.
    Sure...
    Hell, i'll be in Dundalk Md. twice this coming week...:rolleyes:
  16. Mar 20, 2011 at 9:08 PM
    #56
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    :pout: I was taken off the list :(
  17. Mar 20, 2011 at 9:16 PM
    #57
    Brainless
    Brainless Well-Known Member
    Greg
    Moses Lake, WA
    11 TRD Off-Road 6sp manual
    Im in for sure.
  18. Mar 20, 2011 at 9:20 PM
    #58
    VanillaGorilla
    VanillaGorilla Itsnevertoearlytostartbee fingupyourobituary
    Erik
    East Bay Area, CA
    09 BSP Pre Runner SR5
    Tint. (DONE) Soon to come. 3in Llift (OME) Color matched grill (DONE) BHLM (DONE) Tail tint (DONE) Pro comp rims (8069) End goal: Murdered out truck
  19. Mar 20, 2011 at 9:27 PM
    #59
    FamouzStarz
    FamouzStarz NMSAF!
    2013 Tacoma Baja / Supercharged
    Super Charged, Icon Stage 5, Rigid Grill / Light Bar, Fuel 20" Wheels / Blade Tires, Shell Color Matched, Roof Rack, KatSkinz Interior, and other stuff
    do these work with the partsgeek.com grills or oem only?
  20. Mar 20, 2011 at 9:32 PM
    #60
    jamant12
    jamant12 Active Member
    Mark
    Texas
    '11 Tacoma OR DC
    WeatherTech mats, Goodyear Wrangler Duratracs
    Please count me in if there's still room on the list! Thanks!
Thread Status:
