Pre-order SALE - High Lift Hood Struts for the 3rd Gen - through Dec 31!
Discussion in 'Automotive Group Buys' started by SpikerEng, Dec 29, 2019.
  1. Dec 29, 2019 at 7:19 AM
    SpikerEng
    SpikerEng [OP] Well-Known Member
    Leon
    Portland, OR
    Our hood strut kits for the 3rd Gen Tacoma have completed prototyping, and are now in production and available for purchase. Kits ordered now will be shipped in early to mid-January.
    To sweeten the deal for you having to wait, we are putting the kits on a 10% off sale, valid now through end of Dec 31. Use coupon code H82W8 at checkout.
    https://spikerengineering.com/product/16-20-tacoma-hood-strut-kit
    If you're not familiar with the Spiker Engineering hood struts, we have been making the unique "high lift" hood strut kits for the 4Runners and 1st and 2nd Gen Tacomas for a long time.
    These are the only kits available that allow you to set your hood height up to 6" higher than stock, giving you unparalleled access and lighting, not to mention saving you from banging your head against the open hood if you're over 6' tall.
    To emphasize, you do not have to set the height higher than stock, you can choose whatever height suits you. Check out the beauty of the high lift hood capability and comparison to stock height:
    As with all our kits, all components are made in the USA, down to the shipping tubes. All hardware is included, consisting of heavy gauge gloss black powder coated brackets, heavy duty multi-grip rivets, and OEM quality high lift gas struts with an industry leading 5 year warranty. And our pricing is more than competitive with other similar kits.
  2. Dec 29, 2019 at 8:21 AM
    pngo121
    pngo121 Well-Known Member
    Phi
    Pittsburg, CA
    16' TRD Sport DCSB 4x4
    Doesn’t look like much prototyping, just looks like copying of redline.
  3. Dec 29, 2019 at 8:35 AM
    SpikerEng
    Leon
    Portland, OR
    They are obviously similar in that they both use hood struts and mounting brackets, just like 99% of all hood struts out there.
    Our kits allow you to raise the hood 6" higher than stock prop rod or the Redline kits, which is especially helpful on the 3rd Gen Taco with its anemic stock open height. Not only that, our kits allow you to vary the open height to your liking during installation. And yes, that does take quite a bit of prototyping to get right.
    rlx02, Babybluetaco and Nicklovin like this.
  4. Dec 29, 2019 at 12:21 PM
    ICU1
    ICU1 Well-Known Member
    Does the higher opening interfere with Caliraised ditch light brackets and light kit?
  5. Dec 29, 2019 at 12:24 PM
    SpikerEng
    Leon
    Portland, OR
    In trucks with ditch lights, we recommend setting the hood height to just below where the ditch lights will interfere with the hood. Here's an example on a 2nd Gen:
  6. Dec 29, 2019 at 12:47 PM
    @T.A.C.O.M.A
    @T.A.C.O.M.A Well-Known Member
    Los Angeles
    unfortunately it looks like this would interfere with my aux fuse/relay box. Any picture of the exact hole it mounts to under the hood, driver side?
    SpikerEng[OP] likes this.
  7. Dec 29, 2019 at 1:02 PM
    SpikerEng
    Leon
    Portland, OR
    The kits does not use existing holes, it requires drilling new holes for brackets under the plastic trim piece:
  8. Dec 29, 2019 at 6:20 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  9. Dec 29, 2019 at 6:23 PM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
  10. Dec 29, 2019 at 6:43 PM
    Bigdaddy4760
    Maner
    Poolville Texas
  11. Dec 29, 2019 at 6:57 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Yea, a day late again Brother. Wish I had known about these sooner. My Redlines have been in the garage since before Xmas.
    Thanks for the tag though.
  12. Jan 11, 2020 at 5:45 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Ordered!!!! Thanks!
  13. Jan 11, 2020 at 5:50 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Question: After installation do the plastic trim pieces go back on?
  14. Jan 11, 2020 at 9:20 AM
    SpikerEng
    Leon
    Portland, OR
    Yes, the plastic trim piece goes back in place after the strut brackets are installed.
    Pablo8[QUOTED] likes this.
  15. Jan 11, 2020 at 10:06 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Awesome thanks. It probably would have been obvious when actually doing the work - I just didn't see it in the PDF.
    SpikerEng[QUOTED][OP] likes this.
  16. Jan 11, 2020 at 10:14 AM
    SpikerEng
    Leon
    Portland, OR
    Good eye, the instructions do not specifically state to reinstall the trim piece. I'll add that step, to make it clear!
  17. Jan 11, 2020 at 11:17 AM
    ICU1
    Is it possible for the TW discount or a military discount?
