pre-own 100K: What oil should I use???
Discussion in '1st Gen. Tacomas (1995-2004)' started by xbangu, Mar 19, 2009.
  1. Mar 19, 2009 at 5:06 PM
    xbangu
    xbangu [OP] Member
    Austin-Texas
    2006 Indigo TRD
    Hello-
    I just bought a 1999 Tacoma 4 cylinders (2.7??), the truck now have 100K and do not know what oil the last owner used. I would like to use a motor oil that will help extend the life of the truck, but not sure what to use.
    Syn sound good, but after reading it might cause leak...
    Any suggestion will be appreciates.
    Motor oil= 5-30w??
    Oil Filter= brand??
  2. Mar 19, 2009 at 5:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Use a good synthetic. The use of a synthetic causeing leakes is a myth. 10w-30 is a good oil for that motor, but use what you would like. :)
  3. Mar 19, 2009 at 5:21 PM
    xbangu
    xbangu [OP] Member
    Austin-Texas
    2006 Indigo TRD
    If it does not cause leak then I am all for it. Now my oil cap read 5w-30, 10w-30 should be ok too???
  4. Mar 19, 2009 at 5:23 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    the weight on the cap is for the most fuel efficency. thats what the truck was "built" for.
    I use 10w30 in my 96 full synthetic and i havent had a problem. got it at 61K, now have 127K
  5. Mar 19, 2009 at 5:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Either 10w-30 or 5w-30. When My 2.7 got to 100K, I switched to 10w-30, and it ran great. Hell, still is. I saw the guy that baught it from me not too long ago. For the filter, use an OEM Toyota filter. They are cheap, and filter better than most.
  6. Mar 19, 2009 at 5:25 PM
    xbangu
    xbangu [OP] Member
    Austin-Texas
    2006 Indigo TRD
    Will do 10w-30 as you guys suggested.
    Thank you!!!
  7. Mar 19, 2009 at 5:27 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i also ran a K&n filter on my truck..i switched to a mobil 1 filter. Works just as well.
    Watch the deals and coupon section of this forum for deals at advance auto..5 qts mobil 1 and a filter for $30. Cant beat it
  8. Mar 19, 2009 at 7:34 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Synthetic oils tend to penetrate further than regular oils and it's a really good cleansing agent, cleaning buildup. Because of this, it can cause 'seeping'. The oil can get past certain seals and you might notice more oil consumption.
    The benefits of using synthetic oils is far better than the seeping or consumption it may cause.
  9. Mar 19, 2009 at 7:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    http://www.oilsandlube.com/myths.htm
    Myth #1: Synthetic motor oils damage seals.
    Untrue. It would be foolhardy for lubricant manufacturers to build a product that is incompatible with seals. The composition of seals presents problems that both petroleum oils and synthetics must overcome. Made from elastomers, seals are inherently difficult to standardize.
    Ultimately it is the additive mix in the oil that counts. Additives to control seal swell, shrinkage and hardening are required, whether it be a synthetic or petroleum product that is being produced.
  10. Mar 19, 2009 at 7:42 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    ^X2
    Chris just gave you the best advice on your oil situation, if cost is an issue there are plenty of syn blends designed for high mileage vehicles which are a little cheaper. But at a minimum you need to use a syn blend, but full syn would your best situation. Kudos to Chris for recognizing that the Toyota filter is your best money spent. IMO Mobil products work great and always easy to obtain.
  11. Mar 19, 2009 at 8:34 PM
    Muy Grande
    Muy Grande Well-Known Member
    Dallas, TX; RGV, TX
    06 DC TRD
    Suspension: DHoes up front, Dakar and OME out back. Audio: Alpine w205 w/ pair of Alpine Amps, Image Dynamic 6.5 Component Speakers up front and Image Dynamic Subs in the Back. Armor: ARB Bull Bar, Rocktek rear bumper and custom rock sliders. Other: Rigid Industries LED Light Bar, Platinum DieHard Battery, BlueSea Fuse Block, rear lights, bed lights, leds inside.
    From my experience, I bought a used 1993 Toyota Pickup with 95k miles in 2000. It currently has 234,876 miles. The oils I used have been Valvoline conventional 10w-30 and every now and then (usually when the oil was on sale) I would use Valvoline Max Life. I have always used Fram oil filters (PH3614).
    I buy this stuff at Wal-Mart. Usually my oil change comes out to $15. I have always used Valvoline and Fram with no problems.
    If I find something that works I usually stick to it. For my 2006 Taco, I use Valvoline and Fram oil filters.
    You could always buy a box of Toyota Brand filters (10 filters) for about $50 and be good for the rest of the year.
    Considering that you have a high milage vehicle (over 75k) Max Life is probably a good oil to use since it has a special additive system.
  12. Mar 19, 2009 at 9:11 PM
    Blackened Taco
    Tony
    Virginia
    Another huge myth ......... Now that I am using synthetics I can drive a kajillion miles between my oil changes. FAIL ........ stick to your manufactures recommendations regardless of the type of oil being used. Also one has a better chance of blowing seals buy using wrong weights and overfilling. Some people feel that because they have a 100K vehicle They need to use 20-50. Stay within manufactures specs.
  13. Mar 22, 2009 at 2:07 PM
    Tech's Taco
    Tech's Taco Member
    Washington
    99 PreRunner SR5
    I used all different brands of oil, but the brand that I've noticed giving me a difference in it running/sounding smoothly, but also seeing a difference in gaining a mile more per gallon was Royal Purple (5W-30). If you don't mind spending $8 to $10 a quart, this oil is a winner by a long shot! At any rate, choosing different brands of oil is a personal preference, yet my buddies and I use Royal Purple. Good luck!
  14. Feb 27, 2013 at 4:02 PM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Just picked up a 6pk of Mobil1 10w/30 at Costco for $36.99 + tax. Not a bad price. Really over all a few bucks extra for the protection it gives vs conventional oil is minimal.
  15. Feb 28, 2013 at 7:08 AM
    Devout
    Devout Well-Known Member
    Seattle
    03 TRD 4X4
    None yet
    It was on sale last month for $10 off. :eek:
    Goes on sale every other quarter. :p
  16. Feb 28, 2013 at 8:24 AM
    ARB1977
    ARB1977 You done messed up a-a-ron
    North Texas
    15 DCSB Prerunner 4.0L
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Remember the difference between 5W and 10W is startup flow. Once it reaches to operating temp it's all the same 30W. Your not getting better protection. I run 0W or 5W. 148K with no issues.
