Pre-Runner, can I lift it higher?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pschmidt, Nov 29, 2012.
  1. Nov 29, 2012 at 6:38 AM
    pschmidt
    pschmidt [OP] Active Member
    I have the Toytec/Eibach 3in lift in the front on Bilsteins, and the Toytec AAL in the rear with Bilsteins. Most threads I've read state 3" is the max you should lift, but does that apply to the Pre-Runner or just the 4X4?
    I'm not entirely sure what is the limiting factor here, is it CV angle in the front?
    If I was to lift the truck higher, the front is easy, but how about the rear? Blocks? Shackles?
  2. Nov 29, 2012 at 6:40 AM
    mtwil9
    mtwil9 Well-Known Member
    Birmingham
    12 TRD Off Road 4x4
    Bilstein 5100 F&R Eibach at .85 with top plate spacer, 1.5 AAL,LR UCA's Tinted Windows, Weathertech Floormats, Ultra Gauge, 20" light bar behind grill
    Since you have a pre runner you dont have cv joints in the front. You could do some spindles in the front with that being said with a new leaf pack in the rear.
  3. Nov 29, 2012 at 6:43 AM
    pschmidt
    Sorry, should have clarified. Is the total lift amount dictated by the CV axle on the 4X4, which obvioulsy doesn't apply to my truck since it's 2WD?
  4. Nov 29, 2012 at 6:52 AM
    dirtymike
    dirtymike Well-Known Member
    mike
    orlando fl
    2nd gen
    Fiberglass,spindles, coils, 4"leafs, gears&locker, no skids :-/
    Its dictated by the upper and lower ball joints they can only cycle so much. They are the real limiting factor if you jack your truck up take the coil over out you can only move the. Spindles so far up and down
  5. Nov 29, 2012 at 8:52 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    this. Your still limited. But you have the option of being able to sit at 4'' of lift with no problems. But it won't cycle any better then ours reall due to the joints.
  6. Nov 29, 2012 at 9:18 AM
    pschmidt
    Thanks for the info.
    If I wanted to get another inch out of my existing hardware, is it as simple as raising the spring perch on the front Bilsteins? In the rear a set of 1.5" shackles would work, correct?
  7. Nov 29, 2012 at 9:24 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    4 inch spindle with 3 inch bilstein. Super high!
  8. Nov 29, 2012 at 9:57 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    What springs do you have?
  9. Nov 29, 2012 at 10:04 AM
    pschmidt
    In the front I have Eibach/Toytech. The rear is stock leaf pack, with a 2" AAL.
    Sorry for the rookie questions, this is the first vehicle I've lifted, the rest have all been lowered.
  10. Nov 29, 2012 at 10:06 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Keep the angle of the u-joints on the drive shaft in mind....and carrier bearing vibes if not reg cab or using aftermarket single piece drive shaft. Not sure how much shim angle you can add to make up for it on the leafs either.
  11. Nov 29, 2012 at 1:26 PM
    pschmidt
    I will definitely keep that in mind. So far, so good with a little under 3" all around.
    My thoughts are to try running the Bilsteins one setting higher, and add a 1" shackle in the rear. Is there any reason why that shouldn't work?
  12. Nov 30, 2012 at 5:41 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Don't see why not. AAL or the shackle thing would be preferable out back due to the sensitivity to axle wrap on these trucks, especially with manual tranny. With the oem rake you could probably do 5100s set at 1.75 up front with the 1" shackle out back and still have 1.75 of rake because both of my 2nd gens had 2.5 higher in the rear. I just like the AAL option because of the weak 3 leaf packs. When I did 2.5 up front with 1.5 AAL out back on the 05 access cab, I still was 1.5 higher rr but the truck looked perfectly level. On the 08 reg cab I just did TRD bilsteins with .5 top plate spacers up front to get 1" lift and did nothing out back and it has 1.75 rake higher in back. Just barely noticeable more wheel gap in rr. Didn't want to lift as much this time and had the TRDs in the attic to replace the base tokicos with since I didn't use them on the 05. I will most likely get 5100s again because the ride quality improvement at some point. My 05 lifted more with 5100s and E load 18s rode better than the 08 with TRDs and C load 16s does.
