Pre runner engin to 4x4 problems
Discussion in 'New Members' started by jamesdean118, Mar 1, 2023.
  1. Mar 1, 2023 at 5:41 PM
    jamesdean118
    jamesdean118 [OP] New Member
    James
    2006 tacoma
    Swapped engine from pre runner to 4x4 engine
    So my original 4.0 engine out of my 2006 tacoma blew. So I had a good deal on a used 4.0 2006 4x4 engine. Put it in and it won’t stay running. Says cam shaft sensor. I changed them both, still won’t stay started. Please help! I’m going nuts.
  2. Mar 1, 2023 at 5:41 PM
    jamesdean118
    James
    2006 tacoma
    Oh I should also say, it did run really strong for about 10 minutes then would die.
  3. Mar 1, 2023 at 5:43 PM
    Bishop84
    Bishop84 Well-Known Member
    Connectors reversed? I cant remember if you can misconnect them.
  4. Mar 1, 2023 at 6:40 PM
    jamesdean118
    James
    2006 tacoma
    @Bishop I will check that and see what happens. If that fixes it, I’ll get you a beer lol.
  5. Mar 1, 2023 at 6:48 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Poor connection or pinched wires when you installed the wiring harness some place.
    Did it trip any more codes.
    Double check the ECM ground
    The ECM is still not seeing the cam sensor signal so shuts off the fuel.
  6. Mar 1, 2023 at 9:38 PM
    jamesdean118
    James
    2006 tacoma
    I will check that asap!!! So it shouldn’t matter if it’s out of a 4x4 4.0? Thank you!!!
    Bivouac likes this.
  7. Mar 1, 2023 at 9:42 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Absolutely not an issue being from a 4x4 donor, a 1GRFE can be found on shit ton is vehicles. It was an installation issue for sure.
  8. Mar 2, 2023 at 11:54 AM
    Bivouac
    As long as all your original engine harness and ECM is being used.
    The Engine has no idea it came from a 4x4
