Pre-trip recommendations before taking long trip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FePumpr, Apr 2, 2021.
  1. Apr 2, 2021 at 2:53 PM
    FePumpr
    FePumpr [OP] Active Member
    So I'll be taking my 2015 SR5 across 3 states for the first time. When I purchased it in Nov. I had my mechanic conduct a complete inspection and found nothing concerning. So I'll assume it'll do fine, but would like to know how some of you go about doing pre-trip inspections. I know to do the usual checking of all fluids, tire pressure (not needed with sensors), inspect the belts, making sure all the fluid housing bolts are tight, etc. Anything else to check for? Thanks in advance.
  2. Apr 2, 2021 at 2:54 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    Make a good playlist
  3. Apr 2, 2021 at 2:57 PM
    FePumpr
    Haha! That I always do.
  4. Apr 2, 2021 at 3:01 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Depends on mileage. When is the spark plug service due? Clean MAF sensor? Any other service coming up (trans, brakes)?
    whatstcp likes this.
  5. Apr 2, 2021 at 3:05 PM
    El Cucuy
    El Cucuy Well-Known Member
    Paul
    2020 TRD PRO Super White "CHINGAO"
    stockish for now
    I am leaving for TX from FL this Sunday. I have a small air compressor, tire plug kit, Kimber 45 acp, 7" AR pistol, extra ratchet straps in various sizes, 550 cord and a new 8X10 heavy duty tarp in the event I bring back stuff from TX that wont fit under the tonneau cover. Also a small medic bag, prior paramedic so I always have one in my car. I will most likely take the cargo carrier that goes into the hitch and leave that in the bed too. I have yet to take this truck on a long trip so I too am breaking it in, 900 miles each way. Oh, and I just received the radar/laser detector today so that will be installed under the rear view tomorrow to help with the smokies.
    FePumpr[OP] likes this.
  6. Apr 2, 2021 at 3:22 PM
    FePumpr
    Not sure when the spark plugs were last changed. Thought about changing those out along with the wires, just to know that those are fresh. Then what is the MAF sensor?
  7. Apr 2, 2021 at 3:28 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    What is the mileage on your truck?? Do you have the prior maintenance records on your truck? If not your list of things to do will be a little longer. First need to know total mileage.
  8. Apr 2, 2021 at 3:31 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I took mine into the shop, told em I was going on a trip, and had em look it over with an alignment. easy peasy
    would highly suggest getting some seat spacers for the back end of the seat, made a huge difference for me in long term driving comfort. Would also suggest checking/removing your mudflaps...mine were the old factory ones, one came loose at around midnight driving through Panguitch in the middle of nowhere Utah, and made such a noticeable slapping sound I thought my engine was about to blow. Most stressful 30 mins of my driving life.
  9. Apr 2, 2021 at 3:53 PM
    FePumpr
    I'm at around 105K and I did see the Carfax before purchasing. Everything looked good there.
  10. Apr 2, 2021 at 3:55 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Get the latest maps for the GPS.
  11. Apr 2, 2021 at 4:06 PM
    Waasheem
    Waasheem
    2007 xrunner
    4.0 or 2.7?
    MAF mass airflow sensor. Very easy to damage so be very careful. I removed mine to clean, but some guys leave it in and clean it in place because they're so fragile. Damage it, engine probably won't start and definitely won’t run right if it does start. I picked up some crc maf sensor cleaner for the task, carb cleaner MIGHT work. If you don't have new plugs to put in you could regap them. Coil over plug systems don't have plug wires to change. How to info can be found by searching, for both plugs and cleaning the throttle body and maf. Something I like to do when going on a long drive is to dump in some Jectron with a full tank of premium, or whatever cleaner is your favorite.
    If you have a jump starter box you could bring that unless you're certain the battery is very good. Sounds like you have the armed encounter scenario covered. I guess the right to bear arms is interpreted differently depending where you live. Common things to forget to bring are cell phone charger and clean skivies.
    FePumpr[QUOTED][OP] likes this.
  12. Apr 2, 2021 at 6:07 PM
    xplorn
    xplorn Well-Known Member
    Ken
    Oregon, USA
    '10 DCSB OR
    You are in the window for front wheel bearings if they haven't been touched yet. Disc pads if you haven't inspected.
  13. Apr 2, 2021 at 6:19 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    You're crossing three states, I don't think anything crazy is needed, just the basics you mentioned. Could check the differentials and transmission are full and the lug nuts are tight but that's about as extra as I'd go. It's a Toyota, basic maintenance will get you far. What everyone else has listed is stuff you should consider doing at this point of your trucks life, but isn't probably going to ruin your trip.
  14. Apr 2, 2021 at 7:24 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Check the condition of the Serp belt. Its cheap to just replace it.
    Any signs of glazing or cracks or wear.......
  15. Apr 2, 2021 at 8:12 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    Aw hell no. Those aren’t maintenance items until symptoms show. Just drive and enjoy the legendary Toyota reliability:)
  16. Apr 2, 2021 at 8:16 PM
    Waasheem
    Waasheem
    2007 xrunner
    I’m thinking you only have a little time before hitting the road so yes, don’t tackle some major preventative maintenance. You’ve got the basics covered with fluids and tire pressure. You’ll be fine. Again, don’t forget clean underwear.
