Pre-winch power supply inquiry
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GHGoodwin, Feb 3, 2021.
  1. Feb 3, 2021 at 1:21 PM
    GHGoodwin
    GHGoodwin [OP] Member
    Hal
    NE Ohio
    2021 Tacoma TRD OR - Access
    Direct battery tap winch connector. Partial letter blackout. Partial emblem removal. Rear bed opening stabilizers. Tailgate insert panel that smoothed it out. Raised seats. K&N air filter. Alpine sound system (no sub-woofer). LED interior lights. Front end leveled (+3/4"). Pedal Commander. Rear headrest delete. Drivers side grab handle. Blue SumoSpring frame stops front/rear. Front trailer hitch. New interior 120v power tap. Behind driver rear seat delete to storage platform.
    I'm taking delivery of a 2021 TRD in a couple of weeks. Dealer ruined my '06 (254,000 mis) wiring harness and ECU during service and settled for $9,500. On my '06 I had a winch QD installed directly on the battery terminals and mounted under the hood. No fuse or shutoff. My winch is a Warn Axon 55S (5,500 lbs.) set up for trailer hitch attachment.
    I'm concerned with the Gen 3 electrical system and a direct QD connection at the battery. I could easily fab up a set of 30ft super jumper cables using 0 gauge welding wire and 800amp parrot beak jumper cable clamps for the battery.
    -or-
    Can I direct wire a similar under hood mount the QD like I did on my '06?
    Patience here is appreciated. I will have more questions.
  2. Feb 3, 2021 at 2:15 PM
    mhornco
    mhornco Well-Known Member
    I have a smittybilt x20.. Straight to battery. No issues. Most I have seen also go straight to battery, though there is a guy on here who sells a disconnect switch
  3. Feb 3, 2021 at 4:22 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I'm curious about what exactly the dealer did
    Sterling_vH111 likes this.
  4. Feb 3, 2021 at 5:31 PM
    GHGoodwin
    Hal
    NE Ohio
    Mike - Best as I can get out of them. Pinched the harness (more like abused it) and broke a couple of wires and/or a clip off the end. Tried to run some wiring - battery still connected - around breaks and shorted the entire thing out.
    Too old to get replacement harness. Easier to pay me off.
    Grossomotto likes this.
  5. Feb 3, 2021 at 7:31 PM
    Mike402
    Palm Springs, CA
    Well that was a hellaciously expensive mistake on the tech’s part...yikes
  6. Feb 4, 2021 at 6:23 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    I would direct wire it under hood with a QD. (I dont expect you will have any problems if you also run your ground to the battery directly.) I have an anderson connector that lives under the hood hooked to my secondary battery, with a MLACR tied into the main battery.
    (I would also personally add a 300 MRBF fuse too... I carry a spare fuse, and can always manually bypass the fuse if I have a super massive pull that keeps blowing it repeatedly, but I prefer to have the safety of having the circuit fused when in use... But I have never blown the fuse with lighter pulls.)
  7. Feb 4, 2021 at 7:10 AM
    GladiatorNOT
    GladiatorNOT Well-Known Member
    2017 TRD OR
    Old Man BP51 coilovers Dakar HD leaf springs Icon Delta control arms TRD Pro rims with Kenda Klever RT 33x10.5 tires Exhaust mod TRD front skid, RCI tranny and transfer case skids Southern Style Slimline front bumper Baja Designs S8 bumper light Warn Zeon Platinum 10s winch 4.88 Nitro gears ARB front locking differential ARB twin air compressor X2 Power 27 battery RCI rear bumper with Rigid SRQ lights RCI rock sliders RLD canopy Dometic CFX3 55 refrigerator TRD Pro grill Front & Rear anytime camera Seat Jackers Diode Dynamics Pro fogs
