Pre-wired for cruise control?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Natenite, Jul 29, 2019.
  1. Jul 29, 2019 at 11:48 AM
    Natenite
    Natenite [OP] Well-Known Member
    Springfield Mo
    2003 Tacoma 4d TRD Radiant Red
    I remember stumbling on some info online a while back about some Tacomas being pre-wired for cruise control but not having it completed. Is there an easy way to confirm that my 2003 prerunner is or is not pre-wired? If I understood what I read correctly, I just need the cruise lever and need to cut a hole in the back cover behind the wheel. Any help would be appreciated. Thanks!
  2. Jul 29, 2019 at 12:35 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Your missing more then that unless the hardware is installed in the Engine bay
  3. Jul 29, 2019 at 1:14 PM
    Natenite
    Springfield Mo
    cruiserguy likes this.
  4. Jul 29, 2019 at 2:00 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yeah if you have the electronic throttle system, not the drive by wire most of us have, it looks like you can easily add cruise control. Go for it man. I would if it was that easy to add for mine.
  5. Jul 29, 2019 at 3:05 PM
    pwgarcia
    pwgarcia Well-Known Member
    Pete
    2004 Toyota Tacoma 4x4 Double Cab
    How can I tell if I have an electronic throttle system, vs. drive by wire?
  6. Jul 29, 2019 at 3:12 PM
    cruiserguy
    Elijah
    SEKS
    2004 model year?, you have the electronic throttle
  7. Jul 29, 2019 at 3:23 PM
    pwgarcia
    Pete
    And is it really that simple as just installing the switch in the steering column? I have an automatic so no clutch switch needed, but what about a break switch? Is that somehow wrapped into the electronic throttle? Really appreciate this info because I am DYING to get CC. These old knees would appreciate it too! Thanks for any and all info.
  8. Jul 29, 2019 at 3:33 PM
    cruiserguy
    Elijah
    SEKS
    I don't know if it's that easy because it's not applicable to me but based off what I read there it sure does sound pretty simple to add.
