pre wired or?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Movergod, Sep 10, 2017.
  1. Sep 10, 2017 at 5:20 PM
    Movergod
    Movergod [OP] New Member
    Rob
    2011 Tacoma
    How do i determine if my 2011 Tacoma was prewired for fog lights? It is a 4.0 lt double cab 4X4 I found plug for switch behind a blank dash panel
  2. Sep 10, 2017 at 5:32 PM
    Clearwater Bill
    Billy
    Largo Florida
    Telling us a model might let some folks give an educated guess.
    And you can look behind where the lights mount to see if there are any wires/plugs not in use. They are usually folded back and taped to the harness somehow, so not always the easiest to spot.
  3. Sep 10, 2017 at 6:20 PM
    wingspar
    wingspar Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    Wondering the same thing with my 2011 Taco. If it is pre-wired and no switch on the dash is labeled for it, but wouldn’t it have to be connected to an unlabeled switch?
  4. Sep 10, 2017 at 6:29 PM
    Clearwater Bill
    Billy
    Largo Florida
    .The plug for switch should be taped back to the under dash harness. There are probably a missing relay and fuse in the system as well.
    I just added fogs to my prewired 04 Highlander with those bits.
  5. Sep 10, 2017 at 6:35 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    No I4 trucks are pre-wired for fogs.
  6. Sep 10, 2017 at 6:44 PM
    wingspar
    Oregon
    What is an I4 truck??
  7. Sep 10, 2017 at 6:49 PM
    T4RFTMFW
    2.7 liter inline 4 motors.
    If your truck is a V6, it'll be pre-wired.
    If it isn't.. no dice.
  8. Sep 10, 2017 at 10:28 PM
    wingspar
    Oregon
    It isn't. Sigh...
  9. Sep 11, 2017 at 2:01 AM
    T4RFTMFW
    The 2nd gen OEM fog light install kit was discontinued 2 years ago, but the 3rd gen kit should be identical. They use the same fog housings, and it wouldn't otherwise make any sense to discontinue a kit unless they're just revising part numbers.
    Check online, I think you'll be looking at $150-175 for an OEM kit. Comes with everything you need, all the way down to zip ties. Install instructions from the Toyota FSM.
    I got mine from Toyota of McDonough's website. They were awesome.
