Precision Power (PPI) Powerclass Amps
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by GoatFiddyone, Nov 22, 2016.
  1. Nov 22, 2016 at 11:56 AM
    GoatFiddyone
    GoatFiddyone [OP] Well-Known Member
    Altamonte Springs, FL
    '17 DCLB TRD OR
    I have three PPI Chrome series Powerclass amps for sale. These are the PC1400, PC2400 and the PC4400. These amps are the real deal and some of the cleanest power one will hear. These are the last run of the made in the U.S.A. Precision Power amps and some of the last good amps made. All power plugs and speaker blocks are included with these. One of the amps has a little imperfection but the rest are beautiful. I would prefer selling these as a set and would ultimately like to keep it local (central Florida) because these are heavy (shipping). I am asking $400 for the set and based off of your location, I will have to figure out shipping.
    PC1400
    200 WRMS x 1 @ 4 ohms 400 WRMS x 1 @ 2 ohms
    Length - 11.75" Height - 2.25" Width - 8.9"
    4.5 Hz - 100 kHz
    0.02 %
    Balanced Differential 120 mv - 12 volts RMS 10 k Ohms
    2 - 8 Ohms
    11 - 15 volts
    >500
    >50 V/μS
    Up To +12dB Boost @ 40Hz .7 Amps
    Hp/Lp 12dB/Octave Linkwitz-Riley Variable 20-5kHz
    PC2400
    100 WRMS x 2 @ 4Ω per channel
    200 WRMS x 2 @ 2Ω per channel
    400 WRMS x 1 @ 4Ω bridged
    4.5 Hz - 100 kHz
    0.02 %
    Differential
    150mv - 12 volts RMS 10 k Ohms
    2 - 8 Ohms 4 - 8 Ohms 11 - 15 volts >500
    >50 V/μS
    Up To +18dB Boost
    30Hz, 36Hz, 44Hz and 60Hz
    PC2600 2 Amps
    Two Way, 24dB/Octave Linkwitz-Riley 90Hz
    PC4400
    50 WRMS x 4 @ 4Ω per channel
    100 WRMS x 4 @ 2Ω per channel
    200 WRMS x 2 @ 4Ω bridged
    4.5 Hz - 100 kHz 0.02 %
    Differential
    150mv - 12 volts RMS 10k Ohms
    >50 V/μS
    PC4400 - 1.5 Amps
  2. Feb 23, 2021 at 8:25 PM
    El Toyo Taco
    El Toyo Taco New Member
    2003 Black Tacoma TRD
    Did you sell them?
