Predator step chop
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ryanm, Oct 15, 2019.
  1. Oct 15, 2019 at 4:10 PM
    ryanm
    ryanm [OP] Active Member
    Central Iowa
    2020 TRD PRO Tacoma Super White
    ARB recovery point, Duratracs
    Thinking about cutting the steps off and line-x the tubes, has anyone else done this?
  2. Oct 15, 2019 at 4:12 PM
    newdles
    newdles Well-Known Member
    Achmed
    2019 Tacoma TRD Off- road
    Why? Just curious really because they aren’t strong enough to be used as sliders. The body mounts are weak also and only means for climbing in and out. Aside from that maybe just looks?
  3. Oct 15, 2019 at 4:13 PM
    ryanm
    Central Iowa
    Thought the would be strong enough to work as sliders or at least take a bash vs the frame
  4. Oct 15, 2019 at 4:14 PM
    tcjacado
    tcjacado Well-Known Member
    No, definitely not. They bolt into the rocker panel. Sliders (real ones) mount to the frame.
  5. Oct 15, 2019 at 4:15 PM
    newdles
    Achmed
    They’re mounted to the body. Sliders are mounted to the frame and use much better steel. If you were to go over rocks and do damage it won’t be good.
  6. Oct 15, 2019 at 4:17 PM
    ryanm
    Central Iowa
    Thanks for info, new to truck and figuring things out.
  7. Oct 15, 2019 at 4:19 PM
    tcjacado
    You would be better off selling the predators as they are and buy sliders if off road is your intended purpose for the truck. The steps will get hung up on a rock and break off or severly dent. If you don't or aren't going to hit the trails then keep them on.
    ryanm[QUOTED][OP] likes this.
  8. Oct 15, 2019 at 4:42 PM
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    Yes it has been done before, would work as a stone/cinder block for the rockers.
