Preferred coating for Sliders?
Discussion in 'Armor' started by SagWagon, Jan 19, 2018.
  1. Feb 16, 2018 at 5:05 PM
    #41
    ecgreen
    ecgreen overeducated redneck
    Sean
    2015 4x4 4-banger Access
  2. Feb 26, 2018 at 7:23 AM
    #42
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    they'll look like yours in no time. not looking forward to pulling them off next year to re-paint. hopefully can just touch up along the way.
  3. Feb 26, 2018 at 1:01 PM
    #43
    ecgreen
    Sean
    You should be fine touching them up on the truck. I live in the salt belt, so I have to take them off the treat the frame anyhow.
    Remember, scratched sliders are a sign your truck is used for its intended purpose...lol
    RangerComa[QUOTED] likes this.
  4. Dec 1, 2018 at 9:51 PM
    #44
    flinky
    flinky Well-Known Member
    2017 Black Tacoma TRD Sport
    BUILD -Window tint back windows -Clear Tint front to reduce heat -Method NV's Matte Black 16" (reduced from stock 17") -Pro grille - Prinsu Roof Rack - 40" Light Bar Cut Out - Prinsu Top Rack - ARE canopy (windoor, sliding window, roof rack) - Prinsu Load panels - Baja Designs Sport Fog lights - 2 tepui awnings LIFT -BFG K02's 265/75/R16 -2" lift 2.0 Fox Coil Overs -2.5" lift 2.0 Fox w/ resi (mounted high/ shock stone guard) -Added extra leaf
    Looking for a top coat for my sliders. Looking at undercoats, Bed liners (rust oleum). Notices some are "rubberized" Is this the wrong stuff?
  5. Dec 2, 2018 at 7:16 AM
    #45
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    Rustoleum self etching primer and Bed liner. Multiple coats of each.
    flinky[QUOTED] and outxider like this.
  6. Dec 3, 2018 at 11:08 AM
    #46
    SagWagon
    SagWagon [OP] Well-Known Member
    Geoff
    Portland, OR
    2022 TRD OR
    I’m 6-7 months in with mine after doing this. Expect to recoat regularly. Mine needs touch up already.
    flinky likes this.
  7. Dec 3, 2018 at 12:32 PM
    #47
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Same. Minor areas here and there but uber easy.
    flinky likes this.
  8. Dec 3, 2018 at 9:06 PM
    #48
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    touch up is the key. powder coast is tough to touch up. rubberized stuff is a no no, it will catch on rocks/debris and peel then look like crap. The rusto bed liner is super easy to touch up.
  9. Dec 8, 2018 at 10:35 PM
    #49
    3Six
    3Six Well-Known Member
    NoVa - Ashburn/Sterling
    2017 OR DCSB
    Icon Stage 4, Method NV 305, 285/75/16 Wildpeaks, C4 armor, CMC, CaliRaised Sliders
    I've been looking at clear coat options. I recently bought a set of bare sliders and they already show a bit of rust in the welded sections. Would rather just keep the steel look and not worry about touching them up with black after using them.
  10. Dec 9, 2018 at 7:04 AM
    #50
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    https://www.clearcoating.com/products/metals/
  11. Dec 9, 2018 at 7:51 AM
    #51
    3Six
    2017 OR DCSB
  12. Dec 9, 2018 at 12:45 PM
    #52
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    Hey now. I thought you were a little :crazy: to clear coat bare steel so...... black rustoleum bedliner is easy to touch up. Easier than clear coat cause you can see where it's gone from using them. Otherwise you're just guessing. :notsure:
    outxider likes this.
  13. Dec 9, 2018 at 1:25 PM
    #53
    Wsteven
    Wsteven Well-Known Member
    2018 Tacoma TRD Pro
    Working on them
    I have had fantastic results with POR-15 on so many things from a boat trailer to painting the frame and both front and rear bumpers on a FJ Cruiser I had.. So I Got my new RCI Sliders in Bare Metal and will POR-15 those also. IF you do the full proper steps with Prep and use the POR-15 Primer it holds up very good and you can touch it up fast and easy if ever needed. Only thing I do Not like about the POR-15 is it certainly Stinks bad because it is an Epoxy type Paint. On the FJ Cruiser I did both front and back bumpers front underside it held up very good.
  14. Jan 1, 2019 at 3:17 PM
    #54
    Mad Mark
    Mad Mark Well-Known Member
    18 TRD 4x4 off-road
    When I get mine I plan on using black steel-it. That stuff is pretty amazing.
  15. Jan 1, 2019 at 5:58 PM
    #55
    3Six
    2017 OR DCSB
    What I'll never do again...get bare armor. The cost of prep and time to paint it properly is damn near the cost of powder coat.
    colin1qk and Dirk Diggler like this.
  16. Jan 22, 2019 at 6:11 PM
    #56
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    Guys that used the truck bed liner, are you using the liner on the plates that meet the frame?
  17. Jan 22, 2019 at 6:40 PM
    #57
    Dirty Llama
    Dirty Llama King in the North
    PNW
    2018 Tacoma DCLB TRD OR 4x4
    Sprayed with metalized zinc coating, then painted.
  18. Jan 22, 2019 at 10:05 PM
    #58
    outxider
    Sang
    East Bay, CA
    06 DCSB 4x4
    I didn't. I used rustoleum stop rust black spray paint on the inner side of the plate where it meets the frame.
  19. Jan 23, 2019 at 4:22 AM
    #59
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    Interesting powder coat story: We bought a set of powder coated name brand outdoor furniture 1.5 years ago from a major retailer. It sat outside, uncovered, one summer, one winter, and one summer. We hardly ever use it. This past fall I noticed the powder coat was flaking off all over, in big chunks. There was a two year warranty. After contacting the manufacturer and a few pictures I received a refund check for almost $700.00, original cost, $840.00. In time, most everything powder coated and sold in the last few years will be in the landfill, rusted out or in need of stripping and refinishing. I sure there are examples of powder coating that will last years in the harshest environments. I have not seen it yet on consumer type items. There was thread here recently about an aftermarket bumper that was peeling and rusting badly within a few months, sad.....
    On topic, I would prep properly and paint or POR15. It is better, more durable, and more repairable than powder coat and the rust won't spread under it.
  20. Jan 23, 2019 at 7:56 AM
    #60
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    I put on about 5 layers of self etching primer. I should have got por 15 then done the primer. If I have issues I'll strip them and do por 15 from the ground up. I'm not terribly worried about the exposed parts rusting due to I can actually see it and get to it. I am worried about where the sliders meet the frame where I cant see it. I'm just wondering ( and hoping ) that i can get the frame to slider area as rust resistant as i can to avoid issues down the line.
