preformance parts for 2011 how to improve hp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomas28, Jan 7, 2011.
  1. Jan 7, 2011 at 9:38 PM
    tacomas28
    tacomas28 [OP] Well-Known Member
    2011 trd sport
    looking for ways to increase horse power in 2011 tacoma? any ideas
  2. Jan 7, 2011 at 9:56 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Supercharger??? You can do headers and intake but you won't see huge gains.
  3. Jan 7, 2011 at 9:59 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    Super charger is probably the only thing that will give you more HP.
  4. Jan 8, 2011 at 7:58 AM
    JKD
    JKD Well-Known Member
    Supercharger. Most bang for your buck.
    Running 89+ octane gas in the 4.0 will get you about three horsepower and ten or fifteen pounds-feet of torque.
    Anything else is probably a waste of money (who cares if you gain 0.5 horsepower).
  5. Jan 8, 2011 at 6:09 PM
    ImthePrez
    ImthePrez Well-Known Member
    TN
    06 Prerunner TRD
    really gain 3 hp from 89 octane??
  6. Jan 8, 2011 at 8:03 PM
    JKD
    Are you saying Toyota eliminated the ability of the engine computer to adapt to lower octane gas? That seems very, very unlikely.
  7. Jan 8, 2011 at 8:43 PM
    JKD
    It isn't a matter of "needing" premium. When an engine control system pulls timing to allow the use of lower octane gas, it reduces engine power output. When you use higher octane gas in an engine that has been pulling timing to use lower octane, you get the increased power output.
    I have seen no reason to believe that the control software has been altered to remove that feature, and I can think of no logical reason why they would eliminate adaptive spark mapping.
  8. Jan 8, 2011 at 8:53 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
  9. Jan 8, 2011 at 10:56 PM
    JKD
    Plenty of manufacturers do exactly that on many vehicles. It was true on my '98 Neon DOHC, and it is true on these engines. How could removing it possibly save money? The compression ratio has not changed...the engine configuration has not changed...so the only thing that would change is the engine control programming. There is no cost savings to be had there, and there is no scarcity of memory or processor to make Toyota trim the code.
    There is just no reason for them to have removed the adaptive functionality. Here is a published reference from 2006 that shows the engine output as 239 hp and 278 lb-ft torque, matching the information in the Wikipedia article on the GR series engines. There is also a FJ manual that shows the engine rated on 91 octane at 239 hp and 278 torque. Toyota now quotes engine output for Toyota vehicles using 87 octane gas (and Lexus using 91). Unless you can provide some sort of concrete, documented source that says otherwise, then the reasonable conclusion is that the engine system still functions the same way it always has.
    Great. Was the 2000 Accord V6 engine designed and controlled so that it would run optimally on premium, but would adapt for regular? If not, then their findings are immaterial in any discussion of engines that are so designed.
  10. Jan 8, 2011 at 11:34 PM
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    Coming from 550+HP beast, it feels pointless trying to make a Taco go fast. Supercharger will definitely help, but will fail to meet my expectations. I seen vids on youtube of supercharged Taco's, its just creeping along. Far from stock, but far from fast.
  11. Jan 9, 2011 at 1:31 AM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    URD... Enough said
  12. Jan 9, 2011 at 1:48 AM
    JKD
    The computer adjusts the spark maps. It "re-tunes" on the fly. Of course there is a decrease in performance on the lower octane fuel...that has been the whole point of this discussion. Some manufacturers report the higher numbers and say they achieve those horsepower/torque numbers "When using 91 octane or higher fuel". My '98 DOHC was reported this way. Toyota is now reporting all Toyota brand vehicles' statistics when using 87 octane.
    The code already exists. It would take man hours to remove it. The engine computer is a modern design; it is fast, and it is flashable. It is reasonable to conclude that its design includes sufficient memory for any anticipated reflashed software.
    I posted direct references. They are all 2005 and newer.
    I suppose it is possible that Toyota would intentionally redesign the engine (at great expense) so that they could revert back to the level of engine control technology that was common in 1992.
    I posted three references that attest to exactly that, one a published book from 2006 and one a technical manual from Toyota. If that isn't proof, I have no idea what would be.
    This has strayed far enough from the OP's topic, this will be my final post on this topic in this thread.
  13. Jan 9, 2011 at 3:03 AM
    KalamaKid
    Oregon
    I agree with JKD bro, here man all you need is a CAI, Headers, URD supercharger, upgraded pulley and a calibrated ECU and you've got yourself 400HP... This link will help you go far. Just go check out this link and it will lead you to plenty of parts you need. http://www.urdusa.com/ Follow the X-runner guys if you wanna know more. You have the same engine just different suspension! :D
  14. Jan 10, 2011 at 5:02 PM
    tacomas28
    2011 trd sport
    thanks guys for the help i have looked for the super charger but not sure if i can find one for such a new year tacoma
  15. Jan 10, 2011 at 5:05 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I know for a fact I get 2-3MPG better when filling up with premium. Not sure if that would be considered an increase in performance though.
  16. Jan 10, 2011 at 5:05 PM
    KalamaKid
    Oregon
    A 2010 would fit. Ask the techs at ur dealership but it Should work as it's the same truck as the 2009-2010...
