preload or top-out? whats worse?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JCJarvis, Jan 27, 2013.
  1. Jan 27, 2013 at 6:15 PM
    JCJarvis
    JCJarvis [OP] Well-Known Member
    Jenna
    California
    2013 Pre
    So after realizing how much im going to need for the wheels and tires i want, i have decided that i am going to go with the cheap rount for my lift (for now). So im wondering what is worse, because i know neither are good. i could go with longer front coils over the stock shock, or put spacers and compress the shock.. i think the coils will look better but will it cause the stock shock to leak or break??
  2. Jan 27, 2013 at 6:23 PM
    JCJarvis
    Jenna
    California
    2013 Pre
    because my stock wheels are hideous.. plus the tires i want are almost 400 each
  3. Jan 27, 2013 at 6:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Whoa, what tires are you looking to get?!?! :eek:
    With that kind of money invested in the wheels and tires, the cheapest I'd go would be 5100's for the front.
  4. Jan 27, 2013 at 6:26 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    just be patient and save up!!
    The cheap way just to "get it done now" will satisfy you for a month tops... then you'll want to go the "Real" way, but you won't have enough money to do so because you just bought the spur of the moment cheap lift....
    I'm going to be on my third suspension soon cause I couldnt just shut the fuck up and wait till I had enough $$$ for what I wanted.......DONT BE ME
    and what tire are you looking at that's almost 400 each? My MT/R's are expensive but only 250 each...
  5. Jan 27, 2013 at 6:27 PM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    Wow. Are you bumping up to 33's? What tires and from where? It sounds like someone is taking advantage of you.
  6. Jan 27, 2013 at 6:31 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    If you are wanting to go cheap, both top plate and preload have drawbacks. Top plate extends the amount of shock there is and does possible damage to your ball joints, which could lead to a disastrous failure, that, another guy has a thread going now of his failed ball joints. Preload puts excessive wear on your strut assembly, and the struts may wear much quicker. If eventually you are going to replace the shocks any way, I'd say do preload for now. Though it is a little more difficult to install than top plates. Good luck
  7. Jan 27, 2013 at 6:50 PM
    JCJarvis
    Jenna
    California
    2013 Pre
    They are called creepy crawlers by Maxxis.. i just love them for the way they look and the price was like 359 a piece i think on 4 wheel parts, yes i definately want 33 X 12.5's
    Thanks for the advise :)
  8. Jan 27, 2013 at 7:32 PM
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    And no matter what a shop tells you. Cutting will need to happen.
  9. Jan 27, 2013 at 7:51 PM
    JCJarvis
    Jenna
    California
    2013 Pre
    no i do appriciate the imput i have no problem cutting the inside wheel wells i have done it on all my trucks.. but i want them as big as i can go without it being stupidly non-functional.. you think 33s are way too big on a 3 inch lift?
  10. Jan 27, 2013 at 7:54 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    33s aren't to big. The width is what is going to require alot of trimming.
  11. Jan 27, 2013 at 7:59 PM
    JCJarvis
    Jenna
    California
    2013 Pre
    ooh ok, got it. Thanks
  12. Jan 27, 2013 at 8:06 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    285 75 16 would be better. Its pretty much a 33" tire but not as wide. You'll still have to do some trimming and a cab mount chop if you wheel.
  13. Jan 27, 2013 at 8:09 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    And seriously reconsider before buying anything from 4 Wheel Parts.
    Their reputation is not the best.
  14. Jan 27, 2013 at 8:09 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    tires@400??? um, hmm, ok. maybe research a bit more, 400 is WAY too expensive for a tire, and for a 2wd.
  15. Jan 27, 2013 at 8:10 PM
    SoCaltaco65
    I have to agree 100%, r-tards at best.
  16. Jan 27, 2013 at 8:15 PM
    jandrews
    '09 FourDubDee TRD OR
    Maxxis doesn't make Creepy Crawlers in a 33. They start at 35 and go up from there. They do make a 255 pizza cutter which I doubt would look the way you want.
    Is that avatar picture actually you or did a sorority girl sneak in from Facebook and edit your account?
  17. Jan 27, 2013 at 8:15 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  18. Jan 27, 2013 at 8:15 PM
    GreatBasinTaco
    GreatBasinTaco Well-Known Member
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    These will wear quickly with on road use. They are made for primarily off road vehicles.
  19. Jan 27, 2013 at 8:17 PM
    GreatBasinTaco
    Reno, NV
    2020 Tundra DC
    Lots of stuff
    This. 35" is the smallest size I have seen in 12.5" wide
  20. Jan 27, 2013 at 8:19 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That won't stop 4WP from claiming they can get them, claiming they are ordering them, taking $1600, and then not calling the customer for 2 months to tell them they can't get them.
    They did that to me on my Silverado. I ended up threatening a refund out of them and bought online for half what they wanted, and I've heard a number of similar stories.
    I think it's how they finance their business without paying interest.
