Preloaded tune device
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TommyGunn, Aug 28, 2024.
  1. Aug 28, 2024 at 4:57 AM
    TommyGunn
    TommyGunn [OP] Work Truck
    Da Beach
    2023 V6 4x4 4dr
    Looking for a reasonable priced preloaded tune device for a 2023 V6. Does this forum favor a particular brand or seller? I’m from the car world and use to SCT devices which save your stock tune and other tunes loaded, like street and track. Mainly looking for a performance street tune with possible shift upgrades as well. Thanks
  2. Aug 28, 2024 at 5:06 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Does not exist.
    Tunes must be installed by laptop for the 3rd gen Tacoma - it requires between 1 and 2 ECU flashes to do. This can be a DIY thing (with purchase of cable software, and tune license), or you can pay someone to do it for you. It depends on whether you plan on tinkering with the tune.
  3. Aug 28, 2024 at 5:07 AM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    I don't think there's really a thing like that for these trucks. Most folks seem to be using an OTT or KDMax tune flashed by a tuner.
    TommyGunn[OP] likes this.
  4. Aug 28, 2024 at 6:33 AM
    TommyGunn
    Da Beach
    2023 V6 4x4 4dr
    Okay, thanks. Did not know that. Problem for me having someone flash it would be not being able to flash back to stock for warranty work .
  5. Aug 28, 2024 at 6:39 AM
    atc250r
    Orange County, NY
    I've yet to hear of anyone one here having the dealer notice their truck being tuned. AFAIK the dealer isn't able to dig that far into the PCM nor is anyone their likely to know is what the programming is supposed to be vs what it actually is. I got the OTT tune which helps with the gear hunting on the automatics, adds a little torque, and if desired can make the gas pedal a bit more responsive. I also did a spacer between the upper and lower intake manifolds to put the peak torque at a lower RPM. While not life changing, the two seem to compliment each other nicely. IMO what these trucks really need is a more aggressive gear ratio in the axles.
  6. Aug 28, 2024 at 7:57 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
  7. Aug 28, 2024 at 8:04 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    The dealer (and local emissions testing) can absolutely see if the truck's ECU has been flashed. Whether they care in the end is a different story but if you blow the engine and try to make a warranty claim while tuned it would likely come up.
    https://www.tacomaworld.com/threads/ecu-tune-and-failed-emissions-testing-experience.818248/
    musicisevil likes this.
  8. Aug 28, 2024 at 8:09 AM
    atc250r
    Orange County, NY
    The state run emissions inspection centers in states that have the standard that CA and CO do will see the ECU checksum is not what's expected. Unless things have changed I don't believe the software the dealer uses sees it.
  9. Aug 28, 2024 at 8:11 AM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Any handheld basic OBD scanner can see the CVN checksum. It's a common check on performance cars (especially Dodge Hellcats) and has lead to many warranty denials.
  10. Aug 29, 2024 at 5:40 AM
    TommyGunn
    Da Beach
    2023 V6 4x4 4dr
    Coming from Fords I know they can tell if a tune has been loaded on a car. Maybe it’s just Ford/Chevy/ Dodge that can do that since their systems are easily manipulated by a tuner.
    I’ll have to try the things you mentioned, just want a little more, especially the pedal response.
  11. Aug 29, 2024 at 7:13 AM
    Buggin112
    Buggin112 Well-Known Member
    Portland, Oregon
    2022 Tacoma TRD Off-Road
    Banks Pedal Monster will give you your pedal response. It gets power from the OBDII port, so it won't throw codes like the pedal commander can taking power from the pedal circuit. It is also easily removable for trips to the dealer.
  12. Aug 29, 2024 at 9:58 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    I’d you’re going to use a throttle controller instead of tune, banks is 100% the way to go
  13. Aug 29, 2024 at 10:33 AM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    smoke and mirrors, just press the pedal more, its free
    devinzz1, Chew and BabyBilly like this.
  14. Aug 29, 2024 at 10:38 AM
    atc250r
    Orange County, NY
    If only it were that simple.
  15. Aug 29, 2024 at 10:46 AM
    auskip07
    Skip
    Atlanta, Ga
    look for a pedal commander used or something along those lines. People tend to want more and search it out.
    Tune, Gears, Supercharger.
  16. Aug 29, 2024 at 10:49 AM
    atc250r
    Orange County, NY
    That doesn't mean pressing the pedal more is the same thing. The lag between you pressing the pedal and the truck reacting will be there until you get a tune or pedal commander.
    2024OffRoad likes this.
  17. Aug 29, 2024 at 10:51 AM
    auskip07
    Skip
    Atlanta, Ga
    im not here to help you justify your purchase
  18. Aug 29, 2024 at 12:44 PM
    atc250r
    Orange County, NY
    :rofl::rofl::rofl::rofl:
    Since you know so much, please tell me what I've purchased. You're statement was literally not correct. Stepping harder on the gas pedal does not do the same thing as a tune or pedal commander.
  19. Aug 29, 2024 at 1:07 PM
    auskip07
    Skip
    Atlanta, Ga
    No one cares what you purchased, pedal commander just adjusts the signal to the ECU Its not a hard concept to understand that if it reads your foot at 40% and translates it to 50% as an example. So Yes just press the pedal more (not harder) and you will accomplish the same thing while saving 300 dollars. What magic do you think it does?
  20. Aug 29, 2024 at 1:23 PM
    Buggin112
    Portland, Oregon
    The computer can do it faster than I can. Not all smoke and mirrors.
