Premature Alternator Failure??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by brianrride, Feb 7, 2016.
  1. Feb 7, 2016 at 7:16 AM
    brianrride
    brianrride [OP] Well-Known Member
    TN
    2014 TRD Off Road DC
    About to go under the hood and diag my whining noise...I am 90% sure it's the alternator. Truck is a year and a half old with 73k...anyone else do an alternator this early? Just curious.
  2. Feb 7, 2016 at 7:35 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    That's a lot of miles in 1.5 yrs.
    Whining could be a lot of things.
  3. Feb 7, 2016 at 7:44 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Has it taken in any water while off road? That is the #1 killer of alternators.
  4. Feb 7, 2016 at 7:46 AM
    Bishop84
    Bishop84 Well-Known Member
    Idler bearing, top right, famous for sounding like a failed alternator. Buy a cheap stethoscope and touch it to all the spinning pulleys.
  5. Feb 7, 2016 at 7:55 AM
    brianrride
    TN
    Maybe dodged a bullet on this one...my stethoscope (long screwdriver) is telling me hands down idler pulley next to alternator as Bishop84 mentioned. I'll let you know after I replace it...tks guys.
  6. Feb 7, 2016 at 8:53 AM
    brianrride
    TN
    Quiet as a mouse after replacing this...
    bigfoote13 and whopper like this.
  7. Feb 7, 2016 at 9:14 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  8. Feb 7, 2016 at 8:53 PM
    Lester Lugnut
    OP:
    What mfg/part # did you use for this repair?
  9. Feb 8, 2016 at 11:07 AM
    tgear.shead
    tgear.shead Well-Known Member
    Did that thing actually fail? Or just run dry? More often than not, I find that just greasing noisy bearings will fix the problem, probably just as long as replacing it. Maybe longer, since DIY typically results in a greater volume of grease packed in than a factory bearing has.
    Some careful work with a dental pick set could pop off the seal, then pack in some bearing grease, then push the seal back in place.. might have kept going for years. Even "knotchy" bearings typically go for years after being repacked. Often, the knotchyness is some kind of grime or burnt/dried grease, so repacking it breaks that up and it again turns smooth as silk.
  10. Feb 8, 2016 at 2:08 PM
    brianrride
    TN
    Gates/36173
  11. Feb 8, 2016 at 2:12 PM
    brianrride
    TN
    Sounded like a supercharger under the hood.
    Agree wholeheartedly sir with running dry. Used to repack all of my motorcycle wheel bearings and it worked well. I'm thinking repack the one I took off and save it as a spare...especially since these things are upwards of $50.
  12. Feb 8, 2016 at 4:46 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Just buy the bearing for a few bucks if it noisy it's bad grease won't help it, the bearing was pressed in it will come out.
  13. Feb 8, 2016 at 4:57 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    once you hear a bearing squealing like that.... its done... yeah you can repack it, but its already been worn out....
    Rsoxfan1 and Lester Lugnut like this.
  14. Feb 10, 2016 at 7:24 AM
    tgear.shead
    Nope. Squealing means dry, and possibly contaminated. Very often its still in great shape.
  15. Feb 10, 2016 at 7:39 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The bearing shouldn't be over $10 why waste your time trying to grease a noisy bearing? It won't fix it once the metal is gone it's not coming back.
  16. Feb 10, 2016 at 7:46 AM
    tgear.shead
    Unless you let it run for 5 years, the bearing is probably just dry.
    And no, it isn't a waste of time to grease it. Its a lot LESS time to grease it than replace it, costs NOTHING AT ALL (because you probably already have a bucket of bearing grease), takes a lot less time than it takes to REMOVE and REPLACE it, and will likely last longer than a badly greased new bearing anyway.
  17. Feb 10, 2016 at 12:09 PM
    nd4spdbh
    SoCal
    dont you have to pull the idler off to grease it properly...... may as well just replace it with a new one and go for another 73k miles.
  18. Feb 10, 2016 at 12:10 PM
    tgear.shead
    Why would you want to take it off? Just pop the seal and shove in the grease.
  19. Feb 10, 2016 at 12:33 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No. Just no.
    Once worn and contaminated the new grease may dampen the sound but those metal pieces are still chipping away at the bearings.
    Waste of time repacking a damaged bearing.
    Now if you repacked it prior to the damage, well that is an entirely different story. Like it used to be a regular maintenance item to repack wheel bearings. Now not so much.
    Taco Pete626 likes this.
  20. Feb 10, 2016 at 4:24 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Where did the grease go if the seal is good? It does not evaporate or ware out.
    Jimmyh likes this.
