Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Feb 23, 2018 at 11:25 PM
    #2021
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I hear ya, I just don't want to crank my radio all the time, and have it sound like a window is open when I'm not.
    Neoturner[QUOTED] likes this.
  2. Feb 24, 2018 at 10:51 AM
    #2022
    RedEmpire
    RedEmpire Well-Known Member
    Southern Pines, NC
    2017 MGM Tacoma DCLB 4X4
    Any of those mats does not reduce noise, only vibrations. Go with whatever is cheaper, Noico is good for that. You really need to do a foam/ccf (noico is cheap here as well) over the tiles and then a MLV for at least the rear wall
    Neoturner likes this.
  3. Feb 24, 2018 at 11:53 AM
    #2023
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I did the mlv on the back wall in addition to a dampening material in my last tacoma, worked pretty well. Just trying to find a cost effective way to do it, lol. Thanks for the info.
  4. Feb 24, 2018 at 12:49 PM
    #2024
    RedEmpire
    Southern Pines, NC
    CLD: https://www.amazon.com/Noico-deaden...ie=UTF8&qid=1519505131&sr=8-11&keywords=noico
    CCF: https://www.amazon.com/Noico-waterp...pID=518hOFmf7iL&preST=_SY300_QL70_&dpSrc=srch
    MLV - https://www.tmsoundproofing.com/clearance-mass-loaded-vinyl-4x10-1LB.html
    Velcro for MLV: https://www.sounddeadenershowdown.com/products/velcro®-strips
    More than enough to do 4 doors and back wall. While you are in there, seal up the edges of the rear vents with silicone or butyl rope. Put some foam (anything you got such as https://www.amazon.com/SOOMJ-Acoust...TF8&qid=1519505611&sr=1-7&keywords=sound+foam) over the vent itself and it well be held in by your MLV or even the factory shit MLV if you leave it in. Exhaust vent will still function, but vehicle will be quieter.
    Sound will be reduced and you will actually save money over dynamat which does nothing but control vibrations and make you feel like your car is quieter (due to the 200 dollars spent)
    COdude3 and ToyoDrew like this.
  5. Feb 24, 2018 at 1:47 PM
    #2025
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    That’s what I’ll be doing also. Don’t need no more drama haha
    nightcrawler likes this.
  6. Feb 24, 2018 at 3:06 PM
    #2026
    ECTaco
    ECTaco Well-Known Member
    San Diego
    2018 TRD OR DCLB 4x4 Silver
    What drama are people having with the door locks?
  7. Feb 24, 2018 at 3:28 PM
    #2027
    Neoturner
    Neoturner Large Member
    Turner
    Atlanta
    2016 Black SR5 DCSB 4x4
  8. Feb 24, 2018 at 4:48 PM
    #2028
    ECTaco
    San Diego
    OK, yeah if you don't get them clipped back in properly they could probably pop out, or you could put them in backwards also.
  9. Feb 24, 2018 at 4:52 PM
    #2029
    Georgeee28
    Georgeee28 Well-Known Member
    George
    Central Coast Cal
    Just did this install today and although I forgot to take pictures of the install, this speaker upgrade was worth it. The adapters seem cheap but they served their purpose.:thumbsup:
  10. Feb 24, 2018 at 5:52 PM
    #2030
    Chozer
    Chozer Well-Known Member
    NC
    2018 Tacoma TRD OR DCSB 4X4 V6 Auto
    Doing the tweeter's first, when doing the passenger side pillar with the grab handle, is it different to remove than the drivers side. Video seems to only show the driver side.
  11. Feb 24, 2018 at 5:58 PM
    #2031
    ECTaco
    San Diego
    You don't have to remove the pillars. I know some of the videos show it but I did it without removing them, it's no problem.
    uhplifted likes this.
  12. Feb 24, 2018 at 7:07 PM
    #2032
    KrnTaco08
    LA
    2017 Taco
    I removed the driver side pillar but I didn’t remove the passenger side. Worked just fine
  13. Feb 24, 2018 at 7:26 PM
    #2033
    Ex03
    Ex03 Well-Known Member
    2017 Red Tacoma TRD Sport
    Completely wrong. There are many posts of people that left the pillars on and have snapped clips on the tweeter panel. Removing the pillar takes 30 seconds and is a much cleaner and safer way of doing it. Disconnect your negative battery terminal, pop the caps on the pillar and its 1 or 2 10mm bolts depending on the side. Not worth the risk when its an extra couple minutes to do it the right way.
    uhplifted, Hobbs and bigfoote13 like this.
  14. Feb 24, 2018 at 9:00 PM
    #2034
    ToyoDrew
    ToyoDrew Well-Known Member
    Texas
    17 Inferno TRD-OR DCSB 4x4 (SOLD)
    OVTune, Hertz spkrs & JBL MS-8 DSP, Turn-as-Tail mod, LEDs everywhere, MESOJDM Turn Signal, Bakflip Revolver X2, Pop-n-Lock, Yakima roof rack, & many minor mods
    Removing the A pillars are incredibly easy...and extra minute (or two max) for each side. It is literally 2 bolts on one side, and 1 bolt on the other (plus the plastic tabs that all trim pieces have).
    I would imagine you are not saving yourself much time by trying to squeeze out the tweeter cover without breaking any tabs.
  15. Feb 24, 2018 at 9:02 PM
    #2035
    ECTaco
    San Diego
    I don't know about "completely wrong".There are post about not removing the pillars and having no problems. That's where I learned about it because I was set to remove the pillars before I read you didn't have to. I and many others have done it and it was very simple.
  16. Feb 24, 2018 at 11:14 PM
    #2036
    muddywater
    muddywater Member
    2005 Desert Sand Tacoma 4x4
    I went with the Kicker KS series (supposed to be one level higher than CS and costs more) instead of the CS series because when I listened to them in the store, the KS had less fatiguing highs (silk tweeter) and clearer mids; however, when I installed it in my truck (off the factory deck) there was no bass at all. I panned back and forth and the factory speakers had more bass. This seems odd since they have the same sensitivity as the CS series. Based on all the glowing reviews of the CS series in this thread saying the CS series has some bass, I am perplexed. I am not expecting subwoofer like bass, but I have owned aftermarket 6x9's before and was expecting at least a little. At the moment I am wondering if the Entune Plus deck has less power than the Entune Premium and therefore cannot push the speakers enough to get any bass out of them or if it is just the speakers. I am going to try the CS ones as well and see if there is any difference. I did notice one odd thing. The passenger side has much less bass output than the driver's side regardless of whether the speakers are factory or the Kicker KS even with the balance centered so I am not sure how much that is affecting things
    The tweeters on the other hand were a worthy upgrade and easy to install so thanks to OP!
    bshammer0[OP] likes this.
  17. Feb 25, 2018 at 9:00 AM
    #2037
    Arrowshot
    Arrowshot Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Which speakers did you install (front, rear and tweeter)?
  18. Feb 25, 2018 at 9:07 AM
    #2038
    RedEmpire
    Southern Pines, NC
    I noticed the lack of bass as well. The factory head unit does not have enough power. The doors and tweeters are wired in parrallel as well, so there is power loss there as well. Really need an AMP. After a week or so of break in, I did notice more bass, but still need an amp.
  19. Feb 25, 2018 at 9:12 AM
    #2039
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    @muddywater most people seem disappointed with speakers that don't have entune system that comes on trd trims. There's a note in the OP that suggest it, your experience seems to validate that thought.
    Excuse to get a subwoofer :)
  20. Feb 25, 2018 at 9:22 AM
    #2040
    Arrowshot
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    They also show that these 6 3/4 fit (Kicker 43CSC674, 6-3/4" 2-way car speakers).
