Premium Audio Upgrade for less than $250
Discussion in 'Audio & Video' started by bshammer0, Sep 14, 2017.
  1. Feb 28, 2018 at 9:30 PM
    #2081
    Ex03
    Ex03 Well-Known Member
    2017 Red Tacoma TRD Sport
    The Alpine power pack? Indulge me for a sec. If I go w/ this option, besides what I currently have Kicker door / tweeters. What else would I get? Yes I am a complete rookie here. Side note, would this even be in the same ballpark vs a JL Stealthbox? This option is like ~500 OTD, the Stealthbox setup I am looking at is upwards to 1500 when I am done. I am no audiophile, so I dont want to overspend on something that may not be that much better for my ears.
  2. Feb 28, 2018 at 9:31 PM
    #2082
    Ex03
    There should of been a separate bag of black screws, if you bought it from Crutchfield.
    This was the part #
    Metra HWP-0001
    3 of the 4 holes line up on the bracket, I had to drill a small hole into the mount to screw in the 4th hole.
  3. Feb 28, 2018 at 9:47 PM
    #2083
    GPfromCA
    GPfromCA New Member
    Graham
    I found the screws/clips but no instructions came with the mount. It doesn't seem too obvious either. The clips provided don't match anything.
  4. Feb 28, 2018 at 9:57 PM
    #2084
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Throw out the clips. On the fronts I had to use larger diameter screws and only 3 of 4 holes. The rears worked fine with the supplied screws for the fronts.
  5. Mar 1, 2018 at 1:31 AM
    #2085
    CoastieRon
    CoastieRon Hammocking Fool
    Ron
    Nashua
    Lil' Silver
    Too much.
    I ran the speaker wire through the grommet hole, then Noico'd over the hole. I pealed back the grommet enough to put the wire through.
  6. Mar 1, 2018 at 3:11 AM
    #2086
    LtPeteMitchell
    LtPeteMitchell Well-Known Member
    2018 TRD OR
    The Powerpack is a small 4 channel amp. It has more output than the stock head unit in the truck, but probably not a lot. It’ll have an easier time driving your speakers than the head unit will. It’ll definitely be louder, but if the source you use, like Bluetooth, is crap, you’re amplifying crap.
    No, the Hideaway can’t have the same output as the JL Stealthbox, but unless you’re looking to jar your fillings loose, the Hideaway adds adequate low end.
  7. Mar 1, 2018 at 5:40 AM
    #2087
    Chozer
    Chozer Well-Known Member
    NC
    2018 Tacoma TRD OR DCSB 4X4 V6 Auto
    Thanks for that info. Did you overlap the Noico over the edge of the speaker hole. If so how much goes to other side. I'm trying to understand the easiest way to cut and measure the noico. Do people cut out the spots for the screw holes before they stick it on the door or after? Sorry for all the questions, just trying to be prepared, this noico stuff seems to be the most time consuming to me.
  8. Mar 1, 2018 at 6:39 AM
    #2088
    Chozer
    NC
    Guys the Kicker speakers from OP are back on sale today @ crutchfield, just got my price match.
  9. Mar 1, 2018 at 7:32 AM
    #2089
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    Great question. I actually covered the hole, used the roller on it, then cut the hole out. no overlapping. As for the screw holes, when you use the roller around the hole, you will see where they are, simply cut the noico around the shape. The first door takes the longest. After that, you get a really good idea of what you are doing. I used 1 sheet per door.
    Chozer[QUOTED] likes this.
  10. Mar 1, 2018 at 7:35 AM
    #2090
    Chozer
    NC
    Perfect, I will do the same, thank you for the help.
    CoastieRon[QUOTED] likes this.
  11. Mar 1, 2018 at 7:37 AM
    #2091
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    With that one sheet you should be able to put a strip above the crash bar on the outer skin of the door, as well as below the crash bar & around the speaker hole. Rolling the strips inside the door is a bit of a pain in the ass, but you'll be fine.
  12. Mar 1, 2018 at 7:42 AM
    #2092
    Chozer
    NC
    Good to know, I ordered the noico roller already, so I should be good to go. Thanks again.
  13. Mar 1, 2018 at 8:07 AM
    #2093
    Turtle353
    Turtle353 Well-Known Member
    2016 Taco TRD Sport
    I just used a short screw driver handle and rolled with my palm. I used the rounded back side for tight spaces. I don't think I had any adhesion issues and it looked decently smooth.
  14. Mar 1, 2018 at 9:02 AM
    #2094
    Ex03
    Thanks man! 34 bucks for reading Tacoma world in the morning. Since when does this site pay back, normally it makes me hemorrhage cash.
  15. Mar 1, 2018 at 10:28 AM
    #2095
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    Thanks for this!! Bam, I am happy I waited. i just ordered them, $135.98 with all the needed adapters and harnesses for the speakers. Just have to order the tweeters and I think I'm going to go with the Hideaway from kicker too.
  16. Mar 1, 2018 at 10:43 AM
    #2096
    Hstone556
    Hunter
    Austin
    Well, today was a good day to spend some money I guess.... All Kicker speakers, doors, tweeters, and hideaway sub ordered. Total cost: $422.20.
    dziner likes this.
  17. Mar 1, 2018 at 12:29 PM
    #2097
    The Desert Fox
    The Desert Fox Well-Known Member
    2017 TRD Off-Road DCSB V6 MT 4x4 Super White
    17" TRD Pro Wheels, 265/70R17 Falken Wildpeak Tires, Pro Grill
    I just installed the Subaru/Kicker speakers from this thread today. Wow, what a nice improvement! Well worth the money.
  18. Mar 1, 2018 at 3:32 PM
    #2098
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Anyone install the
    44KSC6904.
    They are also on sale, and have only one tweeter. May be a better match for our truck?
    bobrown14 and CoastieRon like this.
  19. Mar 1, 2018 at 4:17 PM
    #2099
    CoastieRon
    Ron
    Nashua
    Lil' Silver
    Too much.
    I think that would be a better choice. Originally that was my plan. I think the 3 ways is too much.
  20. Mar 1, 2018 at 7:50 PM
    #2100
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Those 2-way speakers are a woofer and a tweeter. So you'll still have double tweeters up front and give up a mid-range speaker.
